Old 01-14-2018, 05:18 PM
JDA_BTR JDA_BTR is offline
Anyone reading this before attaching the canopy should beg borrow or steal some 22g wire and run a pair before the closeout. There are lots of good ideas but this is the easiest by far. If you taped it and pulled it tight before riveting it would not get cut or pinched. I wouldn’t rtv or glue it cuz it’s. nice to be able to pull it thru later if you ever wanted too. Single conductor shielded could work but costs more and the wire is thick enough to to be a real hassle. The
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 01-15-2018, 09:26 AM
Bavafa Bavafa is offline
Originally Posted by Tom023 View Post
Bill, Section 61.check your email. BTW, engine arrives today.
Tom,
Where does one get the section 61? I have the flash drive from VANs and also checked their Website and have not seen section 61.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-15-2018, 11:42 AM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Originally Posted by JDA_BTR View Post
Someone really should put in the plans to run the wire for the canopy locked limit switch when the canopy goes in the frame. I didn?t and it took some creative work to get two wires in the slot from the front of the frame and out the oblong hole next to the switch.
Basically ran it all the way out the back of the frame then used a wire loop in the oblong hole. The loop wire I ran aft then around the switch wire then back to the oblong hole. Pulling the loop forward brought the wire to the oblong hole instead of all the way back. Thenwith a very small thin electrical tape pulled through a second wire.
But what a chore. Tried a lot of other things and ways before this worked.
If you have that set of plans from the thumb drive I can add it to the Wiki in drop box. See link in signature.
Can Anyone upload it? Go to the link and ask for Edit permission.
Or send me your email in PM I will enable.
Thx
Pete
RV14A Tail kit build mostly done
Wing kit in progress
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
change dot org link http://chng.it/KBPtXZYD
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018,19,20 Military exempt but paid any way Cause its worth it.
Old 01-15-2018, 12:13 PM
smash smash is offline
Go to the Van's web site then click on the Support tab and go to the Service Information / Revisions entry and select RV-14/14A. From there you will be able to access most of the chapters of the construction manual: http://www.vansaircraft.com/public/service-rv14.htm
Here is section 61 as posted in the plans revision section of the Van's support site:http://www.vansaircraft.com/pdf/revi...4/RV-14_61.pdf
http://www.smashsrv-14build.com
Old 01-15-2018, 09:00 PM
HAL Pilot's Avatar
Thanks SMASH!
RV-14_61 Uploaded to dropbox. Hyperlink to this thread is on first page.
Pete
EAA 1300
