Old 01-11-2018, 11:55 AM
sglynn's Avatar
sglynn sglynn is offline
Default Panel wire routing Quick Panel
Are you routing wires THRU or UNDER the subpanel?
I'm installing a Dynon/Advanced Quick Panel (which is great) but wondering how and where to route wires from the firewall back to the panel. Are you routing thru the area and drilling holes thru the subpanel to access the area directly behind the panel? Or are you inclined to route wires along the bottom of the ribs and under the subpanel?
I'm thinking about future maintenance. That area directly behind the firewall will be difficult to get to.
Any reasoning for where you are routing would be most appreciated.
Photos of your routing are gold. Please share 'em.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
