Old 03-02-2007, 08:00 AM
avi8tor50 avi8tor50 is offline
Default Tank Leak in 9A QB
Finishing up the wing in my 9A QB. Finally got around to sealing the end plate on my fuel tank. Pressure testing with a manometer to 27" (1 PSI) as recommended by Vans shows a VERY slow leak. The level actually remained stable for 12 hours and then dropped about 3" overnight. Have gone thru the usual soapy solution spray MANY times and can find no bubbles at the end plate, the screws, etc. Gas cap is tightly sealed with fuellube and duct tape. Have sprayed all the rivets in the skin top and bottom and see no bubbles.
Would prefer to avoid removing the tank since it would be a major pain to get to the bolts of the Z brackets.
Would appreciate thoughts of any who have had similar experience.
Peter K
9A QB
Old 03-02-2007, 08:08 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Leak
Did a weather system come through overnight that might account for the change?
Old 03-02-2007, 08:17 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Peter,
I had the same issue when I was testing one of my tanks. Turns out that the barometric pressure changed enough to cause me to have a slight drop. Next time you do your test, log onto weather.com and keep track of what the barometric pressure is doing. If it is going up, then the level in the manometer will fall. Since your manometer level stayed constant for 12 hours, i think the change in pressure is the culprit.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Ron's correct
Try to do the test on a day when the weather will be stable for at least 24 hours. I did this on a tank and had a drop after a high pressure front went through. Didn't really think about it and repeated the test. It was brought to my attention later that this could have been the cause for the drop.
I've had one of my tanks off 3 times (now completely fixed). I can do the Z bracket bolts in about 30 minutes. It isn't that bad and if you don't get a good test in stable weather you may have to do this.
Good luck.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 03-02-2007, 12:01 PM
jsherblon's Avatar
jsherblon jsherblon is offline
Is your garage/shop heated? My garage cooled off overnight when I shut the heater off and went to bed. The next morning the manometer level had dropped. When the temperature was back up, it went higher than the start level.
I put a piece of masking tape next to the tube and marked the level, time, and temp.
Jim Sherblon
-7 Slider Finishing Kit
Stuck in Lodi CA
Old 03-02-2007, 12:58 PM
fstringham7a fstringham7a is offline
Peter
I think Charles Law got ya. Volume is directly proportional to a change in tempreature.
Assuming pressure is constant ....well then we would have to look at Boyles law. Man
do I sound like the old used up retired chemistry teacher that I am............
I had a very small leak in the BNC connector which is part of the capacitance fuel level sending stuff. I believe you probably have the floats so this wouldn't be a problem.
Frank @ SGU RV7A STILL NOT DONE!!!!!!!!!!!!!!!!
Old 03-02-2007, 02:48 PM
Ron Lee's Avatar
Default Franks point may be the culprit
PV=nRT
If T (temp) drops, P (pressure) drops since the volume is the same.
Old 03-02-2007, 03:30 PM
Hi again form the chemistry corner???????So what is the "R" # and units. Also what are the units of temp/ and Units of Pressure.............I know that this isn't getting my plane done but I just couldn't help myself!!!
Frank @ SGU.............Plane Not Done......maybe I should hit the garage!!!!!!!!!!!!
Old 03-02-2007, 04:04 PM
Scott Will's Avatar
Scott Will Scott Will is offline
My QB tank is leaking at the big washer under the main fuel outlet bulkhead fitting on the wing root. Looks like they didnt put enough proseal on the backside of the bulkhead fitting and/or under the large washer. I have to get to it one of these days!!
It took me a while to find the leak.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
