Go Back   VAF Forums > Model Specific > RV-6/6A
Old 01-07-2018, 07:18 PM
Girraf Girraf is offline
Question A case of tall pilot/short pilot
The lady and I both have separate partnerships in certified aircraft but are thinking of selling off and getting our first plane together, an RV-6. Thankfully, we live in an RV rich area with an active EAA chapter. We were able to do a fit check in a local RV-6 to gather more information on whether this platform will work for us. We came away with a few A-HA items.
1. I am 6’3. She is 5’4. The a/c we sat in had about 3” of fwd adjustment on the seat to get her closer but even full forward, she would need the pedals closer to her feet. We could put an extension on the pedal, but we’d also be swapping seats regularly. Anyone dealt with an issue like this? A back cushion might help but then we would need to ensure the ability for full aft stick deflection. Perhaps not a major issue since she is small.
I was told the placement of pedals are one of the design decisions made by the builder and can vary between airframes. The builder of this test bird was tall like me so perhaps this example was ideal for me?
2. Canopy headroom. We sat in a slider. Does the tip up provide anymore clearance? My guess is not. Fortunately I wear a halo headset instead of an over the top, but I probably wouldn’t be able to wear at hat.
Old 01-07-2018, 07:26 PM
Why swap seats? Learning to fly from the ?wrong? seat just takes some practice. Then customize each seat/pedals for that occupant.
Old 01-07-2018, 07:32 PM
Timberwolf Timberwolf is offline
My wife and I both fly our 6 with similar issues. She sewed up a pillow case that fits a custom piece of foam we sculpted to put behind her back. It boosts her forward far enough to reach the pedals fine, yet allows full aft elevator.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 01-07-2018, 08:26 PM
texdog texdog is offline
Thumbs up Swap seats
Judie and I swap seats regularly. I have a long torso, so I have a one inch pad for a seat, gel cushion. Good for over three hours. We slip the bottom pins and move full forward for me. You can custom fit the bottom cushion so it doesn't interfere with the stick. A deep cutout in the bottom seat crotch will do wonders.
T82 Fredericksburg,Tx.
Don't make easy hard!
Master Pilot Award
RV6A owner N6711
L19 sold
ATP/FE/CFI 10 Type Ratings.
Old 01-08-2018, 07:05 AM
catmandu's Avatar
catmandu catmandu is offline
Our 6A has has 6'3", 5'10", & 5'4" pilots moving back and forth between seats. The taller ones use pedals as installed and seats at furthest back position. Tight but not terrible for the taller with about a 2" memory foam seat cushion, perfect for 5'10" pilot (how tall is Van?). For 5'4", there is a second half of a piano hinge on each side to move the seat back base forward about 4", and I added another two inches to the upper seat back extension that wedges into the cross member. Our interim set of seat cushions 'work' with the stick for all pilots, but are not optimum, we'll make a scaled down cushion for the short pilot on the next set.
See post #11 in this thread for pictures.
There is also an archived post about using PVC pipe for removable brake pedal extensions, sorry, I JUST deleted it this weekend from my RV bookmarks since the above setup works fine for us.
Mike C.
Sierra Nevada
RV-6A bought flying (for sale soon)
Super-8 bought flying
Old 01-08-2018, 09:31 AM
Raymo's Avatar
Raymo Raymo is offline
Also consider the AS Almost -14 mod. I am 5' 8" but have tall friends that are not comfortable with my setup.
This mod allows for more aft seat adjustment versus trying to push the pilot more forward.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 01-09-2018, 07:22 AM
That’s great feedback. I hadn’t considered having dedicated seats, but I’m not one to shy away from a challenge! Sounds like there is a plethora of other options to pursue to get the fit correct, some more invasive than others. That keeps the -6 on The top of the list then. Thanks!
Old 01-09-2018, 08:53 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Kenny, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-10-2018, 09:44 AM
Skifreejason Skifreejason is offline
We just installed this in our -6. I'm 6'3 and my partner is "less than 6'" Haven't flown with it yet but, when fit checking it yesterday, will make swapping at lot easier and maybe even possible without removing the seat back.
Otherwise, I hear Tom Cruise uses some extra tall boots when he's filming next to tall women... perhaps he has an extra pair?
Old 01-10-2018, 10:23 AM
kentlik's Avatar
kentlik kentlik is offline
I'll try and get a picture and put it here later.
I would like to see these pictures. I am at a point to make these changes you have done and a couple pictures would be great! 5' 3.5"
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
