Old 03-02-2007, 12:35 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Too much aileron travel
Builders who have gone before me:
I am in that last chapter of the manual where Van's finally decides to disclose the min/max acceptable travel for all the control surfaces. Sadly, my ailerons travel about 1 to 1.5 degrees past the max allowed, and Van's says that it is "probably worth" correcting this (without saying why). I have also heard some stories about bellcranks going "over center" and locking up -- perhaps due to excess travel? I don't know.
At any rate, fixing this little problem does not look easy. Looks like I'll have to detach control rods and remove all ailerons and flaps, drill out the little aileron travel stops, and put in larger ones. I am wondering if anyone has come up with a better way, or determined that such modification is not necessary. A little part of me has considered epoxying on a tiny doubler to the stop or something like that, since we're probably only talking about 1/32" here.
Paul
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 03-02-2007, 12:59 AM
szicree szicree is offline
I don't remember who it was, but somebody on here had what looked like a much simpler aileron stop design. It was essentially a small delrin sleeve slipped over the bolt that connects the pushrod to the aileron. It's worth looking for.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 03-02-2007, 01:11 AM
flydjd's Avatar
flydjd flydjd is offline
Talking Mickey's idea
Hi,
Mickey Coggins came up with a great idea that quite a few people have "borrowed"
http://www.rv8.ch/article.php?story=20040924215600851
Simple and effective and you don't have to worry about getting the bracket spot on ! or changing it after fitting
David J. D.
RV 7A QB (but possibly slowest builder in Europe !)
Hannover,
Germany
VAF # 776
Old 03-02-2007, 02:03 AM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Topic of the Week.
Aileron Stops!!!
http://www.vansairforce.com/communit...ad.php?t=15624
Pete
Peter James.
Australia Down Under.
Old 03-02-2007, 02:55 AM
fodrv7's Avatar
Default No Pics
I was doing my walk-around today and when I came to the Aileron with Mickey's brilliant Aileron Stop that I fittied, I hesitated and thought of taking a pic of it installed.............. but didn't.
Regret it now.
Does anyone want a pic of it installed............ so they can see how it fits?
Pete.
Peter James.
Old 03-02-2007, 09:39 AM
Davepar's Avatar
Davepar Davepar is offline
Paul,
Head down to Lowes or another hardware store with a good selection of parts. Pick up a couple of nylon bushings. I used 1/2" diameter, but am finding that may be a bit small.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 03-02-2007, 09:51 AM
Thanks everyone, this sounds like a perfect workaround! I will give it a try.
Old 03-02-2007, 09:57 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Paul-See Mike Wilson's A-914 thread. For the 9A I think it is the 3/4" or 7/8" size you'll need (in any case, coincidentally, it's the same size as the large diameter washer in that assembly.)
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-03-2007, 12:02 AM
swisseagle's Avatar
swisseagle swisseagle is offline
found on my friends homepage, Berni and Alex http://flyvans.com
I have made the Delrin-Bushing for them.
The Delrin sits with a light press-fit on the standart aluminum spacer.
regards,
Dominik
RV-7A, very slow build
Old 03-03-2007, 05:33 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Paul Eastham
...........fixing this little problem does not look easy. Looks like I'll have to detach control rods and remove all ailerons and flaps, drill out the little aileron travel stops, and put in larger ones. I am wondering if anyone has come up with a better way, or determined that such modification is not necessary......Thanks, Paul
Paul,
Mickey's solution is about as elegant as you can get. Inspired by his creativity, I ordered 1 foot of Delrin rod from Spruce but the 1/2" diameter was woefully inappropriate. Just for grins, I stacked some AN970-3 area washers and as it turns out, is a much better fit....at least I know what diameter rod to order next time.
Alternatively, using these area washers, a builder "could" radius out just enough material from the aileron bracket so that the washers meet the bracket at the maximum design limit of aileron travel. But that is a little like the tail wagging the dog. Better to go the Delrin route.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
