Does anybody know the correct Van's part number for auxiliary access panels for places like baggage floor etc? I'm thinking likely VA-195C and VA-195D?
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
If you are referring to the access panel that is installed in the wing for the stall warner horn (and can be used in other locations) then yes those are the correct part numbers.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF www.DarinAnderson.com
2020 donation sent!
Antenna access. strobe packs, cubby holes, etc? When needed, I fabricate them.
Ya those. I don't mind fabricating but if there is a quick solution from Van's then I'd use my time on other things.
Randy P.
1st time builder
Reserved:C-GRPY
Perfect. Thanks.
Randy P.
1st time builder
Reserved:C-GRPY
