I ordered a bunch of random sizes from aircraft spruce just for the avionics .. I don't recall which ones I used but they fit well. Try #8 .. not many options, you can't really adjust that hole.
Edit: Also test fit the unit once you go down a size, even if it's slightly proud the unit may not touch the screws, I remember this being the case with mine.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
