Old 01-03-2018, 03:28 AM
bobnoffs bobnoffs is offline
Default max temp of proseal
i need to have aluminum welding done close to an inspection hole in a fuel tank. the inspection hole doubler and nutplates are sealed with flamemaster. a call to the mfgr. was an exercise in futility. i can't find any info in the msds sheet. i am wondering what the max temp is i can heat the area to without damaging my sealant. any info is appreciated.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 01-03-2018, 04:48 AM
fixnflyguy fixnflyguy is offline
Default What are you welding?
I'm not sure what your welding, but the RV tanks are made from 2024 (welding not recommended for 2XXX series aluminum)..but you can make a heatshield per say for the nutplate area with some water soaked rags or paste insulation. TIG/MIG welding doesn't create as much heat as torch welding. I have seen Proseal handle some pretty good heat, but do not have factual temperatures.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 01-03-2018, 06:17 AM
not a van's tank. my own design. 5052 aluminum, very weldable. the welds will be 4-5'' from proseal and not a continuous weld. spot 1/2'' skip a couple inches etc. i was thinking about a wet towel and my take on it is that will work but would like to see any opinions.
Bob Noffs
n. wi.
Old 01-03-2018, 09:31 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Here's a typical data sheet. Intermittent exposure to 275F max.
http://www.ppgaerospace.com/getmedia...40_class_b.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-03-2018, 11:04 AM
grubbat's Avatar
grubbat grubbat is offline
Default Proseal
I can not fathom a worse smell that the smell of burning proseal while attempting to weld a piece of alum. It?s kinda hard to describe. You will definitively remember it though.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 01-03-2018, 11:56 AM
thanks gil, looks like i can make this work.
Bob Noffs
n. wi.
Old 01-03-2018, 01:44 PM
Ron B. Ron B. is offline
Can you have a wet cloth or something over the proseal area to keep that cool while welding?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 01-03-2018, 02:50 PM
yep, with a working temp way above boiling i can keep it cool enough with a wet towel. welder says it probably won't even get too hot to touch in that area.
Bob Noffs
n. wi.
