03-01-2007, 05:38 PM
Fuel pick up screen
I noticed that Van's sells a fuel pick up tube with a stainless steel finger screen. I did what the plans show and cut seven 1/16 wide cuts in the tube but to me there should be some sort of screen as well. Is it one or the other? Has anyone put a screen over the cuts in the tube?
Steve
03-01-2007, 05:57 PM
Steve,
I think you probably could. However it might just be more restriction. I ordered the pickup tube with the screen for both the -6A and the 7A. It is full flow and the screen fits around the end of the pickup tube. The open end of the tube fits right against the bottom of the tank by the drain. I really think it is much better than cutting slots in the PU tube, but obviously the slotted tube works.
Wes Hays
Winters, TX
RV-6A Flying
RV-7A Fuse.
03-01-2007, 07:10 PM
I didn't use the slotted pickup tubes ...
that came with my quickbuild. I replaced them with the optional pickup tubes that you referenced.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
03-01-2007, 07:13 PM
i would not
i wouldnt cover the slots with screen. i had the slots first and when the "saftey wire your pick ups " came out i just replaced them with the screen pick ups. the screen is fairly coarse any way. the thought of only picking up fuel from half the tube surface bugged me and i felt the screen was a better method. YMMV
William Weesner/ still kicking.
03-02-2007, 06:19 AM
Moderator/Tech Counselor
I left the slotted pickups in. I don't want anything in there that may get clogged that I can't easily check. At annuals, I blow air back into the tanks to clear anything that may be caught somewhere. I also do a volume check of the fuel system by running the boost pump and timing a measured amount.
JMHO
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
03-02-2007, 06:55 AM
I built the slotted tubes but replaced them with Van's screened units when the service bulletin came out concerning saftey wiring the B nuts to the anti-rotation bracket. Bonus: the new B nuts come crossdrilled for safety wire.
Steve
03-02-2007, 10:49 AM
Thanks for the replies. I decided to stay with the slotted one I made and just drilled the hole for the lock wire. I like Roberta's idea of blowing air thru to clean out any debris, I think that would be easier to do than if a screen was on it. I took the advise of a friend whose on his fifth RV and has never seen a problem with the slots and mentioned if anything smaller does get thru then the gascolator will get it anyways.
Steve
03-02-2007, 11:01 AM
If you're running a carb make sure you put an inline filter in before the pump, quite a few reports of debris clogging the inlet of the little facet. With the screens on I wasn't to concerned about this but I recently added a 74 micron flowezy filter inline anyway. With just the slots in the pick-up tube large debris could easily make it's way to the pump and stop the flow of precious juice!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-02-2007, 06:49 PM
auto tank screens
What I am doing and a couple other Eggenfellner Subaru users are doing is using an automotive sock at the pickup. It can screen out a huge amount of crud and still not get clogged.
Pic & description here:
http://meyette.us/engineAug05.htm#aug26
brian
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
03-02-2007, 07:22 PM
Ya know, there's a screen in the gascolator too. Personally, I'd rather have the gunk pumped out of the tank and traped there than plug the system up at the tank. That'd be bad juju to have a screen in the tank get cloged up in flight.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
