Old 12-28-2017, 03:33 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
That all makes sense and the explanation and reasoning helps, thank you.
I'll go for making the mod to the co-piolot's heat valve.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
1946 Bellanca Cruisair 14-13-2 (73 YRS OLD 8/15/19)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/19 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 12-28-2017, 03:46 PM
Packing blankets work well.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-29-2017, 07:35 AM
HHKing HHKing is offline
Is FF-00084 in the firewall forward kit?
Old 12-29-2017, 07:36 AM
bkervaski's Avatar
bkervaski bkervaski is offline
Yessir!
Old 12-29-2017, 09:25 AM
Bavafa Bavafa is offline
Looking at the drawing, I guess I am not quit getting the purpose of this. Looks like this step will block the outlet of the air to the engine compartment. with this plate (FF-00084) installed, how does the air exit out when the vent is closed. [Edit] Just saw Scott's comment about blocking and it make sense to me now. I am going to at lease drill it and be ready when the blocking plate shows up.
A second question, one of my vent does not close freely and I am wondering if the cable has enough strength to pull it shut. It looks like the piano hinge on the firewall needs to be shimmed to be prevent this. Has anyone else is having this issue?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-29-2017, 10:10 AM
bkervaski's Avatar
I had to take some sandpaper and put it in between the wall of the vent and the door and take off a bit of material to get it to move freely. Just a little at a time, you don't want to over do it or you'll have air escaping.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-29-2017, 12:46 PM
KeithB's Avatar
KeithB KeithB is offline
With respect to the heater vent doors being tight, I would recommend reviewing the following thread in the RV14 forum titled ?Heater control cable tightening?:
http://www.vansairforce.com/communit...eat+vent+cable
I have a Vetterman trombone (no crossover) exhaust on a Superior XP400 which made installation of 2 heat muffs easy, one feeding each heater vent. This week we flew from OH to TX with OATs of -5?F, and in spite of having no interior panels, the plane was warm and I even had to remove my coat and cut back on the vent flow.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 12-29-2017, 03:44 PM
Keith and
Thank you both for the suggestion, I looked at that thread and prefer to have it fixed if possible rather then remedy it with a stronger push-pull cable. the vend door is not sticking but it requires a bit of force to close it completely, what it has been reported in the above thread.
Mehrdad
Dues paid
