This is what Rapco says about their gaskets -
* Be sure that exhaust stack & cylinder flanges are flat
* Install solid gaskets with raised bead facing the exhaust stack flange -- *These may be used in pairs with raised beads interlocked, if desired.
* Torque exhaust nuts to specifications from OEM manual -- Re-Torque after a hot run.
But lots of users prefer the reusable ones -
Rapco RA77611
Lyc 77611
Superior SL77611
