Old 12-22-2017, 10:38 AM
Kapunui Kapunui is offline
Default Partially built Empennage and Wing kit Questions
Hi all, I finally am getting close to the point of starting on my very own rv8. After lurking for a while I am pulling the trigger and starting my dream project. That being said I found a partially built wing and empennage kit and am wondering what I should be looking for in particular. Attached are pictures that I was set already. The wings are from 96 or 97 and I am also worried that I may have some issues with compatibility with a new fuselage kit. Any advice would be much appreciated.
PHP Code:
[IMG]https://photos.google.com/u/1/search/_tra_/photo/AF1QipNMHp9aNt7RMDfDOxW3OxdxH8UjcYmab0oP_8Yr[/IMG]
https://photos.google.com/u/1/search...iZdxxWSbklRT_m
https://photos.google.com/u/1/search...bCFmEcMOfcgz7T
https://photos.google.com/u/1/search...iFwKMg8Knx9eo5
https://photos.google.com/u/1/search...p_lKhfPaT-pHeE
https://photos.google.com/u/1/search...T6JHRW1VRtY22v
Old 12-22-2017, 11:03 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Ryan, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-22-2017, 11:22 AM
SeanB's Avatar
SeanB SeanB is offline
Default Colorado Springs
Hi Ryan,
I see you are in Colorado Springs. There are many builders/flyers in this area and Denver that will gladly offer knowledge and help.
I suggest you contact Van's on the compatibility questions.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 04-23-2018, 04:32 PM
Grumman1 Grumman1 is offline
Hi,
Did you ever get your answer?
I'd be interested in what you found out because I have the same situation.
I have the older wings but was told by Vans that they would fit the new center section.
Russ
