AGM battery analysis ?
There appears to be concensus that a small AGM battery is the least complicated and most cost effective option for E dependant Ignitioin & FI backup. How should you confirm battery fitness for defined service/mission ? Some suggest HF battery tester, some say drain the battery to 10 volts with a light bulb load and measure time. Is there a device or routinely administered protocol to know if battery #2 is fit for the mission ?
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
