Old 12-16-2017, 09:47 PM
DrDrift DrDrift is offline
Default Van's Aircraft Taxonomy
I've been looking for a guide on visually and functionally distinguishing the different Van's aircraft models, but all I found was the "Which RV is Right for Me?" page. In the absence of a guide, I copied the 3-view diagrams from the Van's site and made a simple set of "Airfield Identification Guides for Van's Aircraft"
The first guide is the "Van's Diagram" (sorry), which shows the distribution of aircraft based on aerobatic capability, seating arrangement, and number of seats.
Aerobatic only: RV-3
Side-by-side only: RV-10 (I suppose tandem too...)
Aerobatic and two-seat: RV-4/8
Two-seat and side-by-side: RV-9/12
Aerobatic, two-seat, and side-by-side: RV-6/7/14
I revised the "Which RV is Right for Me" question sequence into a decision flow diagram.
Want 1 or 4 seats, RV-3 and -10 are the only options, respectively.
For two-seat aircraft, the aircraft choice depends on aerobatic capability, seating arrangement, size of interior, and LSA compatibility. I'm sure it's obvious to people who are already familiar with the different configurations, but I was trying to make a diagram that easily distinguishes the main features of the aircraft. Of note, I left off the /A nosewheel options which are subsets for certain aircraft.
Here's a top-view comparison of the 9 RV aircraft with approximately-correct relative size scaling.
Front-view comparison of RV models:
Side-view comparison:
Old 12-16-2017, 10:37 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Originally Posted by DrDrift View Post
What makes you think a -7 isn't roomy inside? Have you ever flown one?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 12-16-2017, 11:09 PM
Fair point! I wasn't trying to slight the spaciousness of the -7, just trying to find a distinguishing characteristic(s) between it and the -14. To answer your questions, I haven't flown the -7 or any other RV, and I'm basing the diagrams off information on the Van's site, namely this paragraph:
From http://www.vansaircraft.com/public/rv14.htm
Probably the first thing you’ll notice is that the RV-14 sits tall. The upright seating position and large bubble canopy provide superb visibility in all directions. The large cabin (as wide as many four-seat airplanes) is truly roomy. Lots of headroom, lots leg room, lots of room between the seats. Big people will like this airplane!
I'll be glad to change the "Roomy Interior?" block if you have have a better way to describe how to decide between the two available two-seat, side-by-side, aerobatic RVs.
Old 12-16-2017, 11:17 PM
Originally Posted by RV8JD View Post
Conventional gear vs Tricycle gear is an important differentiator for most, as is slider vs tip-up canopy. It might make for an interestingly complicated decision chart!
I agree about the gear and the canopy, but you could argue that two decisions are only important *after* you have chosen the airframe. In this case, the diagram would be extended a bit to include the options, but only for some airplanes. The RV-3 would only include the taildragger option, the RV-10 would only include the tricycle, while others would include both.
Part of the problem with the diagram is that it assumes that the "number of seats" is the first decision in the process. While this is probably true in many (most?) cases, it's possible to choose an aircraft starting with the main requirement being a tip-up canopy.
Another way to make an excessively-complicated decision chart is to have multiple starting points. Start with "Ok, so you want a tip-up canopy!", then start filtering based on secondary characteristics. There would be bunches of intersections with other paths through the chart that start from other questions. All the paths would eventually lead to one of the RVs. If it gets complicated enough, it would be a good introduction to aircraft electrical wiring diagrams.
Old 12-17-2017, 06:39 AM
KatanaPilot KatanaPilot is offline
Default Nice play on words
I like the Van's (Venn) diagram.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021)
RV-10 under construction at Synergy Air South
Old 12-17-2017, 07:04 AM
Mel's Avatar
Mel Mel is offline
Default I agree.....
To me, Van's diagram is much simpler.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
rvanstory's Avatar
rvanstory rvanstory is offline
Nice job! I'm building an RV and never fully realized all the differences between their models. Since I wanted 4 seats, my choice was simple. For others trying to decide, this is an easy way to see some of the differences quickly.
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020
Donation Happily Made 2021
Old 12-17-2017, 08:25 AM
rolivi's Avatar
rolivi rolivi is offline
You may consider adding BUY of BUILD since you can't buy a 6 kit anymore.
Rob
RV-6A (Purchased)
2021 Dues Paid, of course
Old 12-17-2017, 12:11 PM
rv9builder rv9builder is offline
Maybe say "larger interior"?
I like what you did?very clever!
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2021
Old 12-17-2017, 01:17 PM
Any of them can be flown non-aerobatically, and the RV-3 is not roomy.
I chose an RV other than the sweet-flying RV-12 because the -12 wasn't a taildragger.
The -12 has exceptional visibility, another distinguishing feature.
Dave
