Old 12-11-2017, 07:16 PM
Rallylancer122 Rallylancer122 is online now
Default Avionics Master Relay
Hi All,
I'd like to install a relay to activate my avionics buss. I have about 40 amps on the buss, and that's too much to run through the rocker switch I have. (I'm rehabbing my Dad's -8, and it already has nice engrave rocker switches, otherwise I'd just replace the switch.)
Can anyone recommend a suitable, aviation grade relay?
DEM
Old 12-11-2017, 07:30 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Check with B and C.
IIRC, that is where I got mine.
40A seems pretty high.............
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-11-2017, 07:36 PM
j-red j-red is offline
You could just use an additional standard relay such as most of us have as our master. I wonder what you have on that bus: 40a seems like a bunch for even older avionics!
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 12-11-2017, 07:48 PM
John Tierney John Tierney is offline
I'm using a standard Cube relay from the local auto parts store.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 12-11-2017, 08:16 PM
Sam Buchanan's Avatar
been here awhile
Biggggggg sub-woofers!
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-11-2017, 08:37 PM
tim2542 tim2542 is offline
Check your load calcs, 40 amps seems way high, like by a factor of 4 or more. If so you can simplify and add lightness with a simple quality switch and dump the relay.
Tim Andres
Old 12-12-2017, 03:57 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Entire panel is only 12.5 amps
AFS5600T, Dynon D10A, Dynon 120, GTN 650, GNS 430, TT 385, TXP 327, PM800BT, iFly 740, NavworxEXP..
Using heavy duty toggle switch(s).
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 12-12-2017, 05:36 AM
Nova RV Nova RV is offline
Stein sells a prefabricated avionics bus with relay, I have one in my build
http://www.steinair.com/product/avio...elay-assembly/
It says 30 amps though so if your 40 amp estimate is correct, never mind
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 12-12-2017, 06:10 AM
vic syracuse vic syracuse is offline
Super Moderator
Ron
You have about 20 amps max here steady state while in flight and everything running on this bus. Stein's avionics bus will work, as will just using another master relay from Van's, Spruce, or B&C. Don't forget to put the diodes on the relay to protect the equipment.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 12-12-2017, 09:09 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Default There is a plethora of options
There are many relays that fit the bill. I use four of these:https://www.alliedelec.com/schneider...d-12/70185034/
I look for silver contacts and coil rating. I run #10 wires from each battery to each relay, the relay?s contacts wired in parallel. There is a primary Avionics #1 relay on the left battery as well as a primary Avionics #2 relay on right battery. There is also an ?Alternate? feed relay on each battery (Avionics #1 on the right battery and Aviionics #2 on the left battery). These relays operate independent of each battery?s master solenoid.
I strongly recommend you not use a single relay to feed your avionics. This is, but definition, designing in a single failure point that will leave you with a dark panel. See if you can split your panel into Nav #1, Comm #1, Nav #2, Comm #2 and so forth to divide the loads between Avionics #1 and Avionics #2.
Carl
