If I recall, Slick recommends a 100 hour timing check and 2 degrees as the max amount of timing shift you should see with each check. As Jesse mentioned, they wear internally and some shift is normal but too much should be seen as a need to IRAN.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
