Here's one I recommend: Digikey V30100S-E3/4WGI-ND. It's current capability and forward voltage drop was selected to limit the maximum charging current to the backup battery. The details of this are beyond the scope of this discussion, but should be fine using any battery the same capacity or greater than the one I used, Digikey 522-1007-ND.
Here's an example of mounting one directly to a CB:
The Gozinas connect to the Master Bus, the Gozouta goes to the ignition breakers/backup battery bus.
V
