If anyone has installed a VM1000C fuel flow transducer on an O-360 carburated engine I'd appreciate some info on where they installed it and how it was mounted. From the manual, it seems that it should be on the outlet of the diaphram pump, with a tee to supply the fuel pressure transducer. Can you just install a tee on the outlet of the pump with the flow transducer directly installed on the tee and then a hose from the transducer to the carb, or do you need to run a hose from the the tee to the transducer and then another hose from the transducer to the carb? Is there a good way to secure the transducer in the required horizontal attitude?
Any help here would be appreciated, and of course, photos would be a bonus.
Thanks loads!
