  #11
Old 02-15-2018, 07:15 PM
WingRock WingRock is offline
Originally Posted by Scott Chastain View Post
This works, too, if you don't mind putting local vegetation to the test with ratchet straps:
That is awesome, gets me thinking about how big the trees are in my yard!
Mark Howell
Davenport, IA
RV8 Tail, Wings and most of fuse done, deep into fiberglass and wire
Old 02-15-2018, 07:18 PM
Originally Posted by BuckWynd View Post
I used a set of heavy-duty ratchet straps to widen the support. They allowed me to spread the bar to about 26-1/4", which resulted in the desired final width of 24-3/8".
Don't pull on anything important, like the support beams in your hangar.
Thanks Buck, I now know I just wasn't spreading it far enough to retain some of the stretch. The rollbar would obviously make a decent spring too!
Mark Howell
Davenport, IA
Old 02-15-2018, 10:07 PM
rv7charlie rv7charlie is offline
No dog in this hunt, but y'all be careful using stretchy stuff to pull with. Those straps might not cut like a cable, but the hardware could take a major chunk out of your skull. A chain hoist would be a lot safer...
Old 02-15-2018, 11:17 PM
KRviator's Avatar
KRviator KRviator is online now
No one said it has to be your yard....
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-16-2018, 04:16 AM
Karlo's Avatar
Karlo Karlo is offline
In Sept. 2012 I had to stretch also the windscreen support after welding two handhold (from stainless steel) to the bow.
https://photos.google.com/share/AF1Q...dzMnRnNTE4U0hB
Karsten Lorenz
Maulburg, Germany
RV-6 #25632, Flying since 20-07-04
O-360, Catto 3-Blade 68"x74"
http://www.mykitlog.com/Karsten/
