Old 12-04-2017, 01:16 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Default Tip: Bending Windscreen Support Weldment
Most builders have had fit issues with weldments at some point. I had a fairly major one with my WD-814 windscreen support/roll bar. When I test fit it initially, it had the usual problems; the forward part of the triangular gussets were raised up a bit, and it didn't fit very well between the vertical tabs and the fuselage cockpit rails. If I snugged up one side, it left me with a 5/16" gap between the tab and the rail on the other side. That's quite a gap:
I checked for possible solutions here, but didn't find much info on the side-to-side issue, so I called Van's builder support. They said it was a common problem and that I should definitely spread the hoop slightly so that the tabs will fit the fuselage. We discussed various ways to do this. I had tried the "armstrong" method of holding one end down on a padded surface with my foot and pulling upward... but I knew right away my back wouldn't care much for that. So I did some thinking... and came up with this solution. I used my cherry picker; securing a chain around the base, wrapping tie-down straps around either side of the hoop and securing them to the base chain and lifting hook, and carefully extending the boom to stretch the hoop:
I would stretch it a bit, let it spring back, and check measurements:
Eventually, after a couple bending sessions and a couple test-fits, I got it to fit just right:
I was so happy with the result, I wanted to share it right away. Van's said that the triangulated braces would probably pull together with the canopy rails with the bolts tightened; if I do any tweaking to those, I'll also share it here.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; engine remounted.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2022... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 12-04-2017, 07:48 PM
greghughespdx's Avatar
Yep, I did something similar and found that the bolts snugged everything up to the rails quite well once tightened down properly.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 12-04-2017, 08:05 PM
Stoo Stoo is offline
Good tip, Martin! The roll bar on my 6 slider needed to be tweaked the other way. Used my floor mount drill press as a big arbor press to make it fit!
Stewart Willoughby, 6 panel/wiring
Old 12-04-2017, 08:06 PM
Neal Trombley Neal Trombley is offline
pure genius
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
Old 02-14-2018, 10:18 PM
WingRock WingRock is offline
Default New Guy Trying to Stretch WD-814
Martin, I have exactly the same gap between the rails and the WD-814. I also spoke with Vans Support and they told me the exact same thing. I attempted to use a hydraulic jack to stretch it and even with an inch and a half of movement it sprung back to it's original size. I got hesitant to push beyond that. Do you have any idea how far you had to go to actually have it retain some of the stretch?
[IMG][/IMG]
Mark Howell
Davenport, IA
RV8 Tail, Wings and most of fuse done, deep into fiberglass and wire
Old 02-14-2018, 10:33 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Boy, I wouldn?t do that operation anywhere near that nice undented skin...
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 02-14-2018, 11:15 PM
Larco's Avatar
Larco Larco is offline
YUP, That top block is just screaming to dislodge under extreme pressure and turn your life into pure H***.
Larry
Old 02-15-2018, 07:23 AM
Allan Stern Allan Stern is offline
Default Yep
But that is the joy of learning what not to do during your build. 😫
Old 02-15-2018, 04:18 PM
BuckWynd's Avatar
BuckWynd BuckWynd is offline
I used a set of heavy-duty ratchet straps to widen the support. They allowed me to spread the bar to about 26-1/4", which resulted in the desired final width of 24-3/8".
Don't pull on anything important, like the support beams in your hangar.
Buck Wyndham
Northern Illinois
RV-8 N8SH
Trying to make OSH22...
Old 02-15-2018, 08:12 PM
Post
Mike & Larry;
You are both absolutely correct!
My wife (who has nothing to do with building aircraft) opened the garage door and the first words out of her mouth were, "back the car out of the garage and move that thing away from the airplane"!
Humbling for sure. I tore my setup down and stopped for the night. I tend to get task focused
Mark Howell
Davenport, IA
