Old 12-04-2017, 10:35 AM
laz laz is offline
Default sealing firewall onRV8 Quick build.
My RV8 is just about done, I painted the last wing and will soon be inspected by the FAA. One of the Items I have left to do is seal the firewall. The current recommendation from Vans is to use pro seal. Here is the problem.
My fuselage was quick built. when they build it they do NOT seal the firewall as per plans. I can seal the top half from inside the baggage area, but the bottom sides and the very bottom are no longer accessible. It will have to be sealed from the firewall side. I can put the pro seal in the small cut outs where the firewall bends around corners but how do others seal this area.
Any input is appreciated.
