12-02-2017, 01:14 PM
AoA tube bent too much?
I'm having a hard time learning the lesson of NOT doing anything critical at the end of the day
Last evening I was trying to figure out how my Garmin Gap 26 heated Pitot/AoA tube tubing was going to be routed around the aileron pushrod. I successfully bent the pitot but may have over bent the AoA tube.
What the consensus? Build on or shorten the AoA tube. The Garmin manual recommends a minimum of 8 inches before any plastic is used due to heat.
Here's som pics:
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
12-02-2017, 02:15 PM
If you can still blow through it a reasonable amount, I wouldn't be too worried about it. There is bugger-all flow through the tubes, so even if you had a restrictor in it in a similar vein to an oil pressure fitting, it would still work - just being slow to respond.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
12-02-2017, 03:14 PM
These tubes are used to sense an air pressure value.
There is no flow through the tube.
So as long as the tube is not completely blocked and it doesn't look like a crack has started that could fail in the future, it will probably be fine.
Scott McDaniels
Hubbard, Oregon
12-03-2017, 09:56 AM
It seems to be fully open...I sure wouldn't want the AoA to be slow to respond though
Yes, there's no flow through these...I think I was more worried about the tubing starting to flatten out.
I've decided to use the tubing as is.
There are no signs of over stress or cracks and the inside diameter of the tubing is only marginally reduced. Also, the tubing will be well supported and not subject to undue loads.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
12-03-2017, 04:11 PM
I haven't installed my Pitot yet so no experience in that area but I was wondering what would be wrong with just shortening the tubes past the bend and then just running your AOA/PITOT tube a bit further?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
12-03-2017, 05:37 PM
Worth buying one of the $30 tubing benders to help avoid this if you end up bending any other tubing. should not be an issue unless there is a leak or the tube is completely squashed flat.
Greg Arehart
N 7965A
12-03-2017, 05:41 PM
been here awhile
Shouldn't have any effect on response. The AOA port on my LRI probe is a hole probably smaller than 1/16" diameter and it responds very quickly to changes in AOA (ram pressure).
12-03-2017, 08:32 PM
That's what I would have done if I rejected the bend.
BUT Garmin requires a minimum of 8 inches from the pitot to any plastic. So I would have had to splice in some more aluminum tubing to get the distance.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
12-03-2017, 08:34 PM
I have one...The Gamin manual says the tubing is designed to be hand bent...so like a robot...I hand bent it...not very smart
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
12-03-2017, 08:36 PM
Yes, I agree. That's why I continued on
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
