Old 11-30-2017, 12:24 PM
fbrewer fbrewer is offline
Default Builder Log from Resale
I'm part owner in a RV-6
It was built in 2001, sold in 2008.
There have been 4 partial owners since 2008. The builder has not been an owner since 2008.
I am able to access the airframe, engine, prop and avionics logs and they are clean, easy to read, and complete.
The annual condition inspection was completed in June 2017 by a mechanic I know and trust.
I cannot find the original "Builders Log". Is this a problem?
Old 11-30-2017, 01:02 PM
Raymo's Avatar
Raymo Raymo is offline
Builder logs are optional and usually done to prove to the FAA that you qualify to apply for the repairman's certificate.
My -7A had a very nice build log when I purchased the half done kit. Since I am an A&P, I opted not to continue with the build log but did mark off tasks in the build manual as they were completed, just so I would know when they were done and who helped.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-30-2017, 01:13 PM
Dugaru's Avatar
Dugaru Dugaru is offline
My vote is "no problem." If it's been flying for 16 years, has complete logs, and has been inspected by an A&P you trust, that's the key info.
Meanwhile, logs that are "clean, easy to read, and complete" have certainly not been the rule during my forays into aircraft buying!! That's a huge plus right there.
Paperwork condition, IMHO, is a surprisingly reliable guide to aircraft condition. Beautiful logs can be faked, but it seems they rarely are.
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2020 Dues Paid
Old 11-30-2017, 02:07 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
I believe the builders log is simply required to prove the 51% rule was met at the time of airworthiness/registration application.
It should have no regulatory use after that even though it should contain useful data to future owners.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-30-2017, 02:51 PM
Thanks Gents
