Old 02-26-2007, 09:54 AM
prkaye prkaye is offline
Default #40 blind rivets
I came to a spot where I wanted to use blind rivets to attach some nutplates today (I changed my mind eventually). But none of the blind rivets I have will fit into a #40 hole, and platenuts are so small I didn't want to enlarge the hole).
What blind rivets will fit into a #40 hole?
What blind rivets are typically used for skins, that will fit the dimple?
I have read through the standard handbook, but there are so many different classifications of blind rivets I can never keep them straight or remember them.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-26-2007, 10:40 AM
Mel's Avatar
Mel Mel is offline
Normally the MK-319BS rivets are used here. They are 7/64", so the nut plates must be drilled out slightly.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-26-2007, 11:44 AM
Radomir's Avatar
Radomir Radomir is offline
Spruce has 'em..
http://www.aircraftspruce.com/catalo...erryRivets.php
I used MSC-32, but the above one is apparently a replacement for it. It is correct size, unlike MK-319BS.
Radomir
RV-7A sold
Old 02-26-2007, 01:38 PM
GAHco's Avatar
GAHco GAHco is offline
Cool The ones that are made specificaly for that.
Part #CCR264SS3-(grip in 1/16ths) is the correct part number for the Steel Cad Plated Nutplate Rivet.
If you want stainless with a black moly dri-lube its CCR264CS3-(grip in 1/16ths)
We, as well as many other Aircraft Fasteners stock these. We usually bag them in 50's
They are not as cheap as commercial pop rivets but they do a nice job and you don't have to drill out the ears on your nutplates.
To see these go to http://www.gen-aircraft-hardware.com...143~143&id=144
Then select your part numbers within the drop down boxes.
We sell allot of these. I've even got some on my 6 that I am building.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 02-26-2007, 02:19 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by prkaye
.....What blind rivets will fit into a #40 hole?......
As the product description suggests, 3/32" blind rivets are commonly used to attach nutplates. They REALLY come in handy when attaching nutplates in the close quarters of the trailing edges of the control surfaces. Here is a source of supply.
http://www.wicksaircraft.com/catalog...232/index.html
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
