11-26-2017, 05:35 PM
Solidworks, Vans 3D models, and Garmins 3D models
Ok, this is just plain cool. With Van's recent release of the 3D models for the fwd fuselage area I decided to start playing with a panel design for the RV-10 I am building. I downloaded the RV-10 3D model, the Garmin avionics 3D models and started plugging things together. I'm nowhere near done but even with this simple picture you can see the potential for this. The images on the avionics are just screen shots I took and placed on the screens for a coolness factor.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
11-26-2017, 07:23 PM
Garmin CAD
Please provide a link for the Garmin 3D models.
11-26-2017, 08:10 PM
Links
Here is a link for the 3D drawings from Vans at the bottom are the links for Garmin, Doyon, etc.:
https://www.vansaircraft.com/pdf/pre...ss_Release.pdf
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
11-27-2017, 07:07 AM
broke the code
Originally Posted by mbauer
Thanks Mike,
I had the file "G3XStepFiles.zip" that Van's links to... what I didn't realize is that it contains more than G3X step files, for instance the GTN6xx I was looking for.
11-27-2017, 01:32 PM
RV-14 Panel Part Solidworks Import Error
I tried to import the IGES files into Solidworks 2016 and got a build error on one of the parts. It still imports it, but I'd like to resolve the error.
Has anyone else run into this issue?
On a related note, is there any reason that Van's doesn't make the native Solidworks files available? It would be easier to import them on our side assuming you have Solidworks.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
11-27-2017, 02:19 PM
Build Error
I get one or another error often with IGES and STEP and maybe other files. I ignore them with no issues.
11-27-2017, 05:17 PM
This is why everyone should just use parasolid, like nature intended...
11-28-2017, 07:50 AM
This is common. I frequently get errors from IGES or STEP files downloaded from McMaster. Sometimes you can resolve the errors with the import diagnostics wizard, but it's usually not worth the effort. Accept the errors, and they'll stop warning you.
A few reasons come to mind... One, a complete solidworks model for an RV would be prohibitively complex for most casual users. Two, an enterprising person could take the file set and make their own RV without paying Van's for their design. Three, and probably most importantly, they would have to decide what version of Solidworks to make files available in... Older versions won't open files saved from newer versions, and there's no way to save as an older version. Solidworks is very good at forcing users to update on a regular schedule in order to maintain compatibility... We call it the Forced Update, or the F-U...
Rob Prior
11-28-2017, 09:25 AM
Links
The link to Garmin support (manual) site don't work for me. Is anybody can load the file on VAF if possible ?
Regards
Eric
RV 14A - #140252 - Flying
France
Dues paid for 2020
11-28-2017, 10:40 AM
Regards
Strange... try my Google Drive here
You can find the zip file on garmin.com by going to Aviation... Experimental... G3X Touch... Manuals... G3X 3D Models
