Old 11-26-2017, 01:34 PM
Dean Pichon Dean Pichon is offline
Default Recommended replacement interval for fuel & oil lines?
What is the recommended replacement interval (in either calendar time or hours of accumulated service) for:
  • Flexible fuel lines? (Do the SS braid/PTFE lined hoses carry the same interval as the cloth rubber variety?)
  • Soft aluminium lines? (Mine look still look new, but are a bit long in the tooth...)
Old 11-26-2017, 01:55 PM
vic syracuse vic syracuse is offline
Super Moderator
The Teflon lines are unlimited life. That doesn't mean they shouldn't be checked for any leakage or abnormalities on a regular basis (Condition Inspection time).
The rubber hoses, like the Mil-6000 should be checked regularly, and be replaced at 7-9 years.
Aluminum lines should never have to be replaced. However, they should be checked at the fittings for any signs of leakage. The flares can crack over time if they weren't properly deburred or overtightened.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 11-26-2017, 06:24 PM
Thanks, Vic!
Just the info I was looking for...
Regards,
Old 11-26-2017, 06:44 PM
scsmith scsmith is offline
rubber-lined stainless braid hoses are supposed to be replaced on some certified aircraft (piper and cessna) at 5-year intervals. I replaced mine at 6 years with TS flightlines teflon-lined hoses.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-27-2017, 07:48 AM
JonJay's Avatar
JonJay JonJay is offline
I did the same thing at 9 years. Sent old hoses to Tom and received back a new teflon set.
I recently disassembled the old hoses to salvage the fittings. All of the original hoses where still plyable and fittings tight.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
