Old 11-21-2017, 09:21 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Overtaking by 80 knots please slow down
The other day I was #2 landing on rwy 21 at Tucson. The main runway is under upgrades and the airliners are landing on rwy 21. Appoach asked me to keep my speed up as I approached the airport. When I switched to tower they told me I was #2 behind a Comanche on final. Then they told me to slow down because I was over taking the Comanche by 80 knots.
Honest officer, I wasn't going that fast......
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 18 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 11-21-2017, 10:00 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
I didn't know a Comanche could hover. Weird thing to do on final even if it's possible.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 11-21-2017, 03:39 PM
mike newall's Avatar
mike newall mike newall is offline
Hurry up and wait......
Drives me mad at work when they do that.
Mind you when you enter what you thought was an empty pattern, downwind at 190kts and then spot the guy in the Cherokee turning base you realise what closing speed is...
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2021
Old 11-21-2017, 04:26 PM
airguy's Avatar
airguy airguy is offline
It is fun though...
I dropped into KSJT a few days ago for lunch, was dropping in from altitude with a good tailwind, showing 220 knots groundspeed and he had three students in the pattern - they all got vectored!
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 11-21-2017, 04:56 PM
RV7A Flyer's Avatar
Well, I do hate to be a wet blanket, buuuuttttt....
It may be fun, but is it really a good idea? Aside from giving RV pilots another black eye for "hot dogging", if you have to make a bunch of other airplanes get moved out of your way, or you're blasting through the pattern at twice the speed of everybody else, is that the right thing to do?
IDK, maybe I'm taking this too seriously...
Old 11-21-2017, 05:35 PM
FlyArmy FlyArmy is offline
Going into TUS where anything from C152s, helicopters, commercial jets, private jets, and F16s are routinely landing/taking off, I don?t think it matters what approach/final speed the OP flies. Approach and tower can handle it.
I was at work a month ago going into JFK and had a 110 knot overtake on a 737. Tower gave me a heads up along with my landing clearance (while chuckling), but it was never an issue (I just closed an 8 mi gap to 4).
Plenty of mixed use fields exist with varying performance aircraft. Head should always be on a swivel, proper comms maintained and positions announced if untowered, situational awareness up. At least with an RV or other relatively fast prop plane, you can keep the speed up and drop it to flap speed relatively quickly if not descending, or keep the speed up longer if necessary, and can configure and semi-comfortably fly slow enough to land behind even very slow traffic. I think higher or varying traffic pattern speeds, depending on the type of airfield and it?s associated traffic, isn?t necessarily a safety issue unless it is outside the pilot?s comfort zone and/or ability to maintain situational awareness.
Old 11-21-2017, 05:45 PM
Bevan Bevan is offline
That's ATC's call. Only they know the big picture. They could have asked you to slow down for sequencing. There may have been something else going on that you're not aware of.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-21-2017, 05:47 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
I'm with you on this. The OP was keeping speed up at an airliner-type airport, which is certainly prudent in that environment (and requested by ATC.) Blasting into a GA-airport at cruise speed is another story and the kind of thing that gives RV pilots a bad name.
Unless told otherwise by ATC, I slow to 100 kts a couple miles from the airport- a good speed to mix in with most traffic. Also a good speed to slow down or speed up quickly if needed.
Jeff Point
RV-6, RLU-1 built & flying
ATP, CFI, Tech Counselor, Flight Advisor & President- EAA Chapter 18
Milwaukee
Old 11-21-2017, 07:44 PM
snopercod's Avatar
My Lancair isn't as fast as an RV (wink), but I did have a 20 Kt overtake on a Citation a few months ago. I couldn't help myself: https://www.dropbox.com/s/jiwo3krs2i...rtake.mp4?dl=0
(2020 dues paid)
Old 11-22-2017, 05:32 PM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
I here ya, It's also allot of fun when the tower asks if your a "twin"! Or I will call your base because you and the Pilatus when be arriving at the same time!
