Originally Posted by JonJay
Zero is through the center of the wing cord and the flap tooling holes (center of flap rib)
I looked at it a little differently.
Set the ailerons to zero using either the tooling holes or the wing template, and then make the flaps the same.
If you have a slight twist in any of the surfaces you can check with a short digital level. Get a center reading and readings at each end of each control surface. Minor adjustments can then be made to 'average" stuff out.
I thought if all of the top surfaces average out to the same reading when flaps are zero and ailerons neutral, then the plane should fly straight.
It did in my case...
I found the above was easier to do than to try and use the flap reference holes.
