Old 11-16-2017, 11:16 AM
13brv3's Avatar
13brv3 13brv3 is offline
Default Gear shimmy video
Greetings,
I purchased an RV-3B a few months ago, and I'm finally getting around to looking at the gear leg shimmy. I mounted a GoPro on one of the tie down attachments just to see what this actually looks like, then intentionally provoked it. Pretty interesting if you've never seen it.
https://youtu.be/GaKSJmu1zgw
BTW, this is a good angle to critique landings, so no videos of that :-)
FWIW, I'm familiar with the shimmy causes and fixes, so this is mainly being posted for your entertainment. Don't say I never gave you anything :-)
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 11-16-2017, 12:15 PM
JonJay's Avatar
JonJay JonJay is offline
Fun times. Good example. Now, let's see those landings
(You can always just share your best ones)
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-16-2017, 12:27 PM
Ironflight's Avatar
VAF Moderator / Line Boy
That's a classic! great video Rusty - thanks for sharing.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-16-2017, 01:22 PM
13brv3's Avatar
OK, this is all you get :-)
https://youtu.be/4GbggShsGdE
Rusty
A&P - 2018
Old 11-16-2017, 01:29 PM
JonJay's Avatar
Rusty
Excellent, perfectly executed, ....
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-16-2017, 03:51 PM
Dmadd Dmadd is offline
Daaaaaaammmmnnnnn :-)
Rusty
Old 11-16-2017, 07:25 PM
CAVU Mark's Avatar
CAVU Mark CAVU Mark is offline
Default Haw many takes?
Must have been more than one?
And if anyone can point me to the gear fix thread I would appreciate it. I too bought a RV3 with enough shimmy for the rocketts!
Mark
RV-3 sold - and I really miss it.
Stearman - N2S-5 completed/flying
L3 building for San Diego Air and Space Museum
Misc. others... F4F, F4U, HUP WACO YKS-7, JN4. TBF
Old 11-16-2017, 09:22 PM
13brv3's Avatar
There's no single thread, but a search will find a bunch of different threads.
Bottom line is that the shimmy happens at the resonant frequency for your gear legs. The primary factors for the frequency are the weight of the wheel/brake/pants, and the stiffness of the gear leg. For the most part, the weight of the wheel assembly can't be changed too much, so the main thing we can change is the stiffness of the gear legs. If you do some searches for gear leg stiffeners, or dampers, you'll find more info, but most people end up with a wood strip wrapped in epoxy to stiffen the gear leg. The idea is to raise the resonant frequency to a point higher than normal taxi speeds.
Another "fix" you see a lot is the recommendation to lower the tire pressure. I'm thinking that also changes the frequency by effectively making the tire smaller, but it may also add some dampening by raising the rolling resistance.
The other recommendations are usually along the lines of making sure your tires are as close to perfectly round as possible, and balanced. These go along the lines of trying to prevent the vibration that will get amplified by the resonance. Tuning forks are quiet if you don't hit them :-)
This plane has some form of gear leg stiffeners, but I haven't taken the aluminum gear leg fairings off to see how they're constructed. Adding the stiffeners totally resolved the shimmy on my previous RV-3B, so I'm hoping I can rework them and have the same success. I'll also be getting rid of those aluminum fairings and replacing them with fiberglass. They guy who built this plane had a thing for polished aluminum.
Rusty
A&P - 2018
Old 11-17-2017, 06:17 AM
Jab Jab is offline
Beautiful landing Rusty, thanks for posting those videos. Let me know if you plan to sell those aluminum fairings, I am actually looking for some.
Cheers, Gary
Bought RV-4
KRKW
Old 11-17-2017, 07:41 AM
13brv3's Avatar
Cheers, Gary
Thanks Gary. I'll let you know about the fairings. I guess they would probably work on a 4 if it's the short gear version.
Rusty
A&P - 2018
