  #11
Old 11-15-2017, 07:13 AM
Robb Robb is offline
What's the almost 14 mod consist of ?
Captain Avgas Captain Avgas is offline
Wink
Originally Posted by Walt View Post
You're certainly entitled to your opinion, but the 7A nose gear is NOT fragile.
And of course you too are entitled to your opinion Walt.
However the truth is that the RV7A nosegear was primarily a carry-over design from the RV6A. But the RV6A had a lower gross weight and they were largely built in a previous period during the 80s and 90s when the norm was for a much simpler lighter aircraft typically with a midlife O320 engine, a timber prop, and simple VFR panel. Therefore weight on the nose was generally less and the margin of safety greater.
The period of the RV7A and of the QB kit saw a completely different demographic of builder emerge. Many builders were more affluent and they wanted bigger engines, CS props and lots of third party doodads (and often full IFR panels). Together with a higher gross weight this put greater loads on the nosegear and the end result was that the margin of safety was reduced to the point that it became problematic.
I saw an RV7A that folded its nosegear during take-off at a local airshow earlier this year and it caused $50,000 worth of damage. My best guess is that any RV7A pilot who has an engine failure resulting in a forced off-field landing will need not just good flying skills but a huge amount of luck to not experience a nose gear collapse.
Maybe the word "fragile" is a bit subjective. Let's just say that there is not a lot of structural redundancy in the RV7A nosegear.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 11-15-2017, 07:36 AM
Raymo's Avatar
Raymo Raymo is offline
Check out Allan's video at the bottom of the product page.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-15-2017, 07:38 AM
KatanaPilot KatanaPilot is offline
Default An observation
I have been working on completing a purchased RV-7A project at Synergy in Eugene since February.
During that time, I have watched several builders start and others complete their RV-14's. My very inexperienced opinion is that the RV-14 kits are a lot easier to complete than the RV-7's.
As an example, we had to rebuild the entire canopy section of my RV-7 (tip up). This process took two and a half weeks, despite the assistance of two of Synergy's most experienced A&P's. I have watched several RV-14 tip up canopies be assembled in about a week. The RV-14 stuff just fits, the RV-7 canopy frame requires an inordinate amount of skill and tweaking to get it to fit right. The original canopy was probably airworthy, but it did not meet mine nor Synergy's fit/finish standards. It did become a good test article for verifying a canopy breaker, though...
Clearly, there are a lot of RV-7's flying and a lot of them were built by first time builders. If you are planning on using a build assist program, I suspect the RV-14 might be a wash cost-wise versus the RV-7. It sure looks like it is a lot easier to build. But they are different airplanes with different capabilities.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 11-15-2017, 08:37 AM
Reflex Reflex is offline
KC,
I was in the very same boat as you are. I lurked for quite some time and had decided on the -7. Ordered the plans, did the research and all the rest of the due diligence that should be done before starting the project. My mission was to have a great cross country airplane that could handle the occasional roll, loop, or spin. I wanted to have the option to burn Mogas, and have speed. My wife loves to fly, but 90% of the time, it's just me. Then I/we went to Oshkosh.
My wife and I sat in the -7 and it was OK. When we sat in the -14 she simply said "this one". While at Oshkosh, I spoke to Vic Syracuse and several others and began the due diligence all over. In the end, I choose the -14. The reasons that tipped the scale were:
1) Fits better
2) Still fits the mission
3) Builds faster
4) More stable IFR platform than the -7
I'm giving up some options on the engine, spending more money, and a few knots, but I think I'm getting an aircraft that suites my mission better.
You're not that far from me (by air), if you'd like to come up and take a look at my project or even work for a day (or not), you'd be welcome. I live very close to K64 and if you have something that you're comfortable landing on 2800' of grass (I currently get a Mooney in and out of there with no problems), I'd be happy to show you around my project.
If interested, PM me.
Best of luck,
Fred
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
Old 11-15-2017, 09:54 AM
TimO TimO is offline
KC,
Don't even consider building one until you have flown in both, or at least flown in a 7.
I'm just under 6'2", and the RV-14 is JUST big enough for me to be comfortable.
When I went for my first RV ride, it was in a 6/6A. I was sold on the 6A before I went for the ride, but after the ride, I was actually disappointed in the cabin size, and realized a 2 seat plane of that size did not fit into my family plans and my flying goals. That ride saved me a lot of headache and heartache.
Eventually after owning a spam can, I built, flew, and fell in love with an RV-10. That plane fit everything I needed at the time.
Eventually I had additional goals, and I started looking at the RV-7/7A as a nice additional plane. But when I flew in one, I realized it was too cramped and really wasn't sold on it as the plane to fit me. In fact, I disliked the feel of the cockpit, but would find it just tolerable as a part-time X/C plane. At one point I ALMOST faxed in an order, but I am so so lucky I didn't, as I would have never been as satisfied, had I gone that route.
Then I went to OSH the year the RV-14 came out. Once I had a chance to sit in it, I knew that was a far more comfortable and better option for me. For a tall guy, it's a world of difference.
So, I built a 14A, which I really enjoy...and like I said, it's just big enough.
There are so many RV's out there now that it's crazy to build one without at least sitting in them to compare, and in pretty much every instance, the newer Van's kits are the more comfortable. For the people who like Tandem, the 8 beats the 4 in comfort. (Although some love the handling of the 4 more). People prefer the 7 over the 6 for comfort. Van's keeps making things better as they go, and I believe that as much as people love the 7/7A, if they flew in the 14/14A, many would see that as a pretty nice upgrade.
I'm just not sure what they can do to improve the -10's comfort, but hey, if they do another really nice 4-seater with upgrades, maybe I'll even check that out.
Don't make your decision based on what you see on paper, or what people tell you. Go experience them for yourself. It's too big an investment of your time and money to not be worth the research flight.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
Old 11-15-2017, 10:15 AM
rvbuilder2002's Avatar
Originally Posted by KC10Chief View Post
Also, a lot less motor options out there for the 14. It seems that there are IO-360s under every rock in comparison! I don't think I can burn mogas in the 390 either, right?
When consider engine options, don't lock the RV-14 into only the IO-390.
There are angle valve IO-360 engines that will work also (the prototype RV-14 tail dragger has one).
Scott McDaniels
Hubbard, Oregon
Old 11-15-2017, 11:19 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Originally Posted by TimO View Post
KC,
What Tim says is correct - it's all about how it fits *you*. I'm 6'5" and fit in my 6A very comfortably. But I built it that way. I've been in 7s where I've felt very cramped.
Which is another point - you will get to build it customized to fit you perfectly. In that respect, the space/size differences become probably not that big a deal and things like performance, handling, etc. become perhaps more important relatively speaking.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-15-2017, 11:37 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
I apologize if this sort of thing has been asked before but I'm just looking for some clarification. I've been lurking here forever! I have been flying for almost 21 years now and have always wanted to build my own airplane. I finally came to the realization that there's probably never a good time to build a plane. You just have to do it. I recently ordered the plans for the RV-7 and am currently reorganizing my garage and acquiring the tools I need. I'll probably order an empennage kit after the new year. I was also looking at the RV-14. There's a lot fewer 14s flying than 7s. Also, a lot less motor options out there for the 14. It seems that there are IO-360s under every rock in comparison! I don't think I can burn mogas in the 390 either, right? It looks like the 7 is a little more agile and slightly faster. Personally, I want a great cross country plane that can do the occasional loop or roll.
I'm 6'1" tall and about 215 pounds. My wife is also 6'1" tall and quite a bit thinner. HA! She doesn't like flying as much as I do and I'd probably be solo most of the time. I'm retired from the Air Force where I started out as an aircraft mechanic for the first nine years and then I was a flight engineer for the last 11. I work for Boeing now. Airplanes are no stranger to me and I have thousands of flight hours. I definitely miss all of the flying though and need my own plane! I'm pretty set on the 7 and I realize I'm posting in the RV-7 forum. I just need some enablers to give me that final push over the edge into the 7 instead of the 14!
KC10Chief,
I am not going to get into discussing the 7 vs the 14. After all I am flying a far superior 9A.
No seriously though, since you are in the OKC area I will ask, have you been going to any of the EAA chapter meetings and discussing with local RVers? There are three EAA chapters in the OKC area (24, 1098, UL98). Each of them have RV pilots in them. There are several 7/7A pilots around. I also know personally of three RV14/14A builders in the OKC area. One just received his FAA sign off and will be flying very soon. Feel free to contact me if you are interested in talking with some local builders and pilots.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 11-15-2017, 05:53 PM
6ato14a 6ato14a is offline
Default 6a mods
Please expand on what you did to get more comfort in your beautiful 6a.
I would love to talk to you about the mods if possible. Call me at 303-772- two two zero two or email a number to klmoexpo@gmail.com so I can call you.
Dave
