Old 11-12-2017, 05:10 PM
Lightbulb 3,000 + hours nose gear bolt replaced
Short story long that's how the stock nose wheel gear bolt looks after 6 years of constant abuse. RV9A with over 3,000 of flying hours and 4,200+ landings some of them at places I wouldn't even think of going second time. No modifications to the gear whatsoever all stock.
Replaced with the same AN5-20A bolt per plans added an extra thin washer and used red Locktite on threads. Surprisingly there was no play after cleaning out the hole in the engine mount and the gear leg. Snug fit. If anybody has an ability to analyze the old bolt I would gladly mail it. It would be interesting to know how fatigued the bolt is and how far it is from the failure.
Old 11-12-2017, 05:26 PM
bdserv bdserv is offline
Vlad - did you do the loctite mod to the gear leg itself to keep the leg tight and imobilized in the socket, or is your nose gear on your 9A totally stock per plans?
Bruce
Old 11-12-2017, 06:07 PM
Bruce
Totally stock per plans Bruce. I locktited the bolt threads only.
Old 11-12-2017, 06:26 PM
TX7A TX7A is offline
Considering where you've been...and I've seen the photos...all I can say is WOW! Excellent airmanship, sir.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 11-12-2017, 06:29 PM
Steve Melton's Avatar
that makes me feel better. thanks.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-12-2017, 07:43 PM
bhester's Avatar
bhester bhester is offline
Default Electric fuel pump?
Vlad, have you had to change your electric fuel pump yet? I’ll be going in there to run some auto pilot wires soon and was thinking it might be a good idea to change it, while it’s opened up. I’m at 1100 hrs. and almost 11 yrs. old. I changed my nose gear bolt in Feb. 2017. When do you plan to overhaul the engine? What about engine hoses?
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
Old 11-12-2017, 07:59 PM
Bobby I will keep the aux fuel pump for another year. A fuel hose leading to carb need to be changed it shows a spot by the heat reflector. I'll keep the motor running I have an ambitious plan for it in 2018. When you changed the nose gear bolt was it showing any signs of wear in shear?
Old 11-12-2017, 09:30 PM
Thanks for posting that, Vlad. It's the one part I'm most paranoid about...I'm checking the bolt every 25 hours for tightness and any sign of movement.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
Old 11-12-2017, 09:48 PM
wjb's Avatar
wjb wjb is offline
Looks like a bit of Russian dirt there ... shouldn't hurt a thing!
Bolt actually looks pretty good; it would be interesting to see if a pull test showed any significant weakening.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 11-13-2017, 06:16 AM
Dave12 Dave12 is offline
Hey pal, bring me that bolt. I know the man for the job.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
