Instrument screen and panel light dimming
I've got a Garmin stack, GNA 340, GNS 430, GNC300XL & GTX327. These all came with a nice wiring loom already made up and thw wiring loom has lots of little yellow wires coming from it. I have followed the wiring diagram for the loom and the physical pin numbers which suggest these wires are for dimming the xcreen displays. But I can't find anywhere what to hook these wires up to. I assume a variable resistor/potentiometer. How do I work out what value I need?
Can I hook these up to the same pot I hook up the panel flood lighting (I'm probably going to use some of the little Vans black ball lights or maybe some of the electroluminescent tape)
I've also got a Dynon D10A and EMS 10 and trutrak ADI which have inbuilt lights that I need to dim and I need to know whether I need to separate each of these systems or can work them from the one dimming control.
What is the wisdom on this?
