Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 11-11-2017, 12:12 PM
recapen recapen is offline
Default To the guy in WV that called me about the ADS600B
I tried calling back - it kicked in a faxmodem.
Meanwhile, I looked at my UAT console settings for the ADS600B - it does not have a baud rate setting for the 430W.
While I was checking my settings, I remembered something important that I have had to remind folks of...:
If your plane is in a hangar, your GPS will most likely NOT be able to see the satellites to get a position fix.
Without a position fix, your ADS600B will not come up as ready - but you may be able to get a clean PAPR during a flight if you have it configured correctly.
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
Old 11-13-2017, 11:48 AM
There's also a difference between ADSB and ADS-B OUT+ selection in the 430W
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
