Two things likely at play here - one is that the servo position sensor itself has some mechanical lag internal to the device (slop in the mechanism) before it starts reversing; the other would be that the displaying device (you didn't say if it was Ray Allen or EFIS) might have a "smoothing" algorithm that takes a few seconds to bring the display to the new value to avoid jittery data.
