  #11
Old 11-13-2017, 01:56 PM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Originally Posted by az_gila View Post
I can see an option to open past 90 degrees at times may be useful, but what advantage would it be to make the door removable?
Three big reasons that I like having the door removable.
1: I was able to build the hinge more flush with the outside skin, as I insert the pins from the center of the hinge, and don't need access to the hinge eyelets that are obstructed by the skins at the top and bottom.
2: I was able to leave the door off while building the rest of the plane. Made access much easier, and I wasn't banging into it.
3: First thing I do during the annual condition inspection is pull the door off. Easier access into the baggage area/tailcone, and I can get into the pilots side door without having to push the door out of my way.
Info about the mod:
http://www.goodplaneliving.com/finis...-baggage-door/
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 11-14-2017, 05:56 AM
n981ms's Avatar
n981ms n981ms is offline
I have a different approach. I did not build mine and have no experience with any other RV-10 baggage door but my door does not open far enough to touch the skin of the fuselage unless the key is in it.
Therefore:
1. I take the key out.
2. I cut a wood fuel dipstick to a slight angle on the bottom and to a length that will wedge lightly between the door bottom edge and the wing walk holding the door open as I load the baggage area.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
