Old 11-08-2017, 07:16 PM
Charles in SC Charles in SC is offline
Default James Cowl Intake Question
I have an IO 360 with a forward facing Bendix type throttle body. My question is how much gap should I make between the rear of the aluminum cowl ring and the intake snout where the flex hose connector goes. The cowl stays still and the engine and snout move. Thanks in advance!
RV 7
Old 11-08-2017, 08:00 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
I have the carbed version....about 1/2"
that is what worked out as I assembled from the carb out.
Good Luck,
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 11-09-2017, 05:57 AM
Raymo's Avatar
Raymo Raymo is offline
I have the Airflow Performance FM150 with about 2 inches of clearance. I had to cut a little off the front of the SJ filter housing to get this much, which works well with the A model 3 blade Catto setup. If not an A model, you could probably get away with 1/2".
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
