Originally Posted by von_flyer
I have pin 21 and 42 connected to power (+14vdc) and pins 20 and 41 connected to ground. No joy on power up. Do I need 38 (power control)
Connected to ground? Am I missing something else?
Thanks in advance!
John
Hello John,
For a GTX 335/345 panel mount transponder for which you do not want it to automatically power up each time power is applied, you do not need to ground either pin 38 or pin 59 on connector P3251.
If you change your mind and want the transponder to come on automatically without pushing a button after power is applied, ground pin 38.
For remote mount GTX 35R/45R/335R/345R transponders, both pins 38 and 59 should be grounded.
Steve
