11-08-2017, 06:39 AM
Elevator control stick play
We have a small amount of play in both our control sticks in the fore/aft direction. It isn't much, maybe 1/4" at the grips, and it's consistent for both pilot and copilot. I was told by one experienced pilot that this play was going to screw with me over time and it needs to be tightened up.
I tracked the problem down to the fit between the brass bushing that goes between the base of the sticks and the bar that connects the sticks to the elevator pushrod. There is a slight amount of play between the OD of the bushing and the ID of the welded-on steel tube at the base of the stick. Without having a new custom-fitted and machined bushing made I cannot see an immediate solution to the problem.
Is this play just a feature of RV-10s? Should I tighten it up somehow?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
11-08-2017, 06:46 AM
I ended up machining a new bushing as have many others. That's the only way to get rid of the play. And yes, it will drive you nuts until you do....... Find a friend with a lathe
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
11-08-2017, 11:54 AM
This is a well known, long-standing issue on the 2-seat RV's as well. I'm surprised that Van's hasn't tightened up their tolerance in this area over the years but the fact that they haven't suggests that they don't see that play as a major problem.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
11-08-2017, 12:27 PM
It is not a major problem and it doesn't cause a flight qualities issue (I don't recall any test / flight review pilot ever mentioning it in their evaluation report, but maybe I have forgotten).
It is something that is inherent to all the RV models (except the RV-14), except on the RV-4 and 8 it adds some system play in the roll direction instead of the pitch direction.
Because it is understood that even though it generally isn't noticeable, it is less than idea from a design aspect, when the RV-14 was designed, bearings were incorporated into this location of the control system.
1/4" play at the top of the stick does sound excessive though and probably warrants redoing. A typical new installation is usually less than 1/8".
Scott McDaniels
Hubbard, Oregon
11-08-2017, 12:32 PM
Just curious
if thin brass shim stock or a dab of JB Weld on the outside of the bushing/inside of the weldment would be a kosher solution to the slop?
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
11-08-2017, 02:18 PM
Hey Bill, I wonder how many listers know who your avatar is...I do, and I used to watch that show as a kid.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
11-08-2017, 03:52 PM
I was going to reply earlier but there was an outage aboardships.
Bill Boyd
11-08-2017, 04:00 PM
I used the brass shim stock solution.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-08-2017, 05:13 PM
I?m wondering if maybe Vans fixed this issue because I just completed this step last week and the bushing fit quite snug in the base. In fact I had to convince it to go in that last little bit with a plastic tip hammer.
Dave
11-08-2017, 07:33 PM
I wrapped mine with that aluminum tape used for duct work until it fit good.
David C.
Howell, MI
