Old 11-05-2017, 06:29 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default VFR pilot into IMC
VFR pilot into IMC. That was me yesterday in Springfield Missouri And I didn't get on the gauges for almost 30 seconds. I was at 600 ft AGL under a ceiling totally in the goo and in a turn back to the airport. I was doing what every mishap pilot does, looking out the window searching for the ground. I was lucky and learned from the scare. For 30 years as an Air Force Aerospace Physiologist I taught pilots to get on the gauges. I got humbled, it's easier said than done.
What I learned
- transition to instrument early and especially in a turn
- god saved me this time, I won't ask again
- instrument training starts now
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 11-05-2017, 06:58 PM
Steve Melton's Avatar
IFR = It's For Real
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-05-2017, 07:32 PM
snopercod's Avatar
You did good, Paul, and you're here to tell about it. By coincidence, I encountered a similar situation last week. It's scary.
(2020 dues paid)
Old 11-05-2017, 07:34 PM
bret's Avatar
bret bret is offline
Wow, glad it turned out ok, do you have auto pilot?
Old 11-05-2017, 08:05 PM
Plummit's Avatar
Plummit Plummit is offline
Good on you but remember that even with the IFR rating, you never want to be VFR into IFR conditions. You may be able to keep the wings level but unless you are on an IFR flight plan, you have no idea where the other aluminum or rocks are in the clouds.
~Marc
RV-10
N814RV
2021 Donation Made
Old 11-05-2017, 08:08 PM
Bugsy's Avatar
Default Autopilot didn't save me
I do have autopilot and that's the trap I learned about being a VFR pilot in IMC.
I didn't engage the autopilot because in my moment of panic I didn't want to continue straight into the goo so I initiated a turn back to the airport.
Thinking about it now I should have continued straight and level or slight climb into the weather and then initiate a controlled turn back.
Or better yet admit that METARS yellow means stay on the ground untold I get my ticket.
Avidyne IFD440
Old 11-05-2017, 08:25 PM
Toobuilder's Avatar
Been there, done that, was convinced I was going to die.
Glad you are still here.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-05-2017, 08:59 PM
Chkaharyer99 Chkaharyer99 is offline
So glad you're alive to tell your story and no one got hurt. It takes courage to admit but it's good for souls. Yours and ours.
The conditions in your part of the country are so different then what I'm used to here.
Charlie
RV-8
Old 11-05-2017, 09:46 PM
Been there, done that. A couple of indistinct cloud layers <apparently> converged on me. Did a 180 and RTB'd. As the OP said, I should have engaged the AP and had "George" do the 180 for me.
'Twasn't scary, but it was a little sobering.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-05-2017, 10:47 PM
punkin punkin is offline
Default Me too
I punched my AP and focused on altitude...decided I would count to 30 and if not cleared, I?d climb. I knew it was clear above me, I thought I had a good hole to the airport, ?one little cloud? was about 15 seconds of total vision loss.
I?d had my ezpilot installed for about a month...I had just listened a few months ago to an ATC track of a guy flipping out in brief IMC, and I didn?t want to be that guy. At about an 8 count, I cleared, continued to airport and landed in MVFR.
Someone else said sobering. Indeed.
Scott
1995 RV-4 bought from original builder
1993 RV-6 (sold to good home)
2002 Rans S7 Courier
Double exempt but happy to contribute! Dues paid 2016-2018
www.know-love.org
