11-05-2017, 04:49 PM
Originally Posted by DanH
You installed fire transfer material.
Search "firewall insulation".
Ah I see. Not book. I dont necessarily agree with your conclusions, but I understand your line of reasoning. Thanks for the clarification.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
11-05-2017, 05:39 PM
Try testing it with samples of your products, then you will know. That's what Dan has done with numerous products (and most likely your product) and shared his results with us. Thanks Dan.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-05-2017, 06:12 PM
Where did you source your Ti from?
Thanks for the great write up.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
11-06-2017, 04:52 AM
Hey Mehrdad,
It's from Titanium Goat, a lightweight backpacking supply company. Check out the top of the first post for the direct product link.
11-06-2017, 05:11 AM
titanium needs pressure to help it burn. when exposed to normal pressure under the cowl it should not burn.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
11-06-2017, 08:59 AM
Originally Posted by SMO
I have 185 hours on mine. I used stainless tape to seal up the stainless foil encasing ceramic fiber. I had a major oil exposure event at about the 60 hour mark - left the dipstick in the hangar  - that resulted in hot oil everywhere including the firewall (quick turn around and land when I noticed oil seeping out the oil filler door on take off). The stainless tape is holding up fine.
Thanks for the info.
Do you recall specifically what stainless tape you used (or the supplier)?
Scott McDaniels
Hubbard, Oregon
11-06-2017, 11:28 AM
Don't really want stainless tape for this application. Melting is desirable to vent the overlap seam.
Take a look at Polyken 339:
http://www.herculesindustries.com/si...cs/25pstul.pdf
or Polyken 345SW:
http://catalog.berryglobal.com/catal...5SW_092915.pdf
Dan Horton
RV-8 SS
Barrett IO-390
11-06-2017, 12:30 PM
This makes sense but what about the adhesive? Wouldn't the adhesive "melt" or soften and allow off gassing in either case?
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
11-06-2017, 01:08 PM
Fair point. Probably yes.
Dan Horton
RV-8 SS
Barrett IO-390
11-06-2017, 01:32 PM
Belly fireproofing
What size area would you or did you cover for fireproofing the belly? Specifically:
Wider than the cowl outlet at the front? Full width of belly?
How far back from cowl outlet did you insulate?
Did you keep it the same width front to back, or taper towards the rear?
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
