Old 11-01-2017, 03:12 PM
Allison Allison is offline
Default Flight without spat
Hi everyone,
The nose wheel spat on my 6a is broken. I need to fly it home home for repairs. I read somewhere this is not allowed. Any info would be appreciated. Thanks.
Old 11-01-2017, 03:56 PM
Bicyclops Bicyclops is offline
If you fly with the nosewheel pant on but the mains off, you would change the location of the center of pressure forward which would potentially be less stable. With the nosewheel naked and the mains covered, it would theoretically be more stable. I think you'll be OK. If you are worried, you could pull the mains and uncover all three. We know that hundreds of RVs have flown like that.
Ed Holyoke
Old 11-01-2017, 04:51 PM
Ron B. Ron B. is offline
Flew from coast to coast in an RV-10 without a nose wheel pant only thing noticeable , airspeed loss.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-01-2017, 05:35 PM
xblueh2o xblueh2o is offline
Ask yourself this question,
With the removal of the fairing that covers the nose wheel, is there a solid way of retaining the fairing that covers the nose gear leg?
Can you fly it with both the nose wheel and nose gear leg faring removed? Yes.
I don't know what the regulations regarding that sort of thing in South Africa are though.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 11-01-2017, 05:46 PM
KRviator's Avatar
KRviator KRviator is offline
I've flown the last 30 hours with the main gear fairing and spats on but the NLG pant and fairing removed after it was damaged towing the -9 with a flat NLG tyre.
Not a problem other than the speed loss.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 11-02-2017, 09:39 AM
Thanks for all your replies. 'Bullet' made it home for repairs. Perhaps one last question, the nose wheel spat mounting brackets are all broken, I want to fit something similar to what the later nose wheel models have, i.e. the 7a I saw today. But I can't find it on the vans website, I'd prefer to order ASAP. Can anyone help me with a part number or correct name. Thanks in advance.
Old 11-02-2017, 10:41 AM
Raymo's Avatar
Raymo Raymo is offline
Assuming you have the -7 nose wheel fork, the following are the pant brackets.
U-713C-L NOSE WHEEL PANT BRCKT $17.00
U-713C-R NOSE WHEEL PANT BRCKT $17.00
You'll also need the associated hardware.
2 ea: 3/8 x 24 x 3/4 Allen screw
2 ea: AN960-616 flat washer
2 ea: 3/8 lock washer
8 ea: K1000-08 platenut
8 ea: AN507C832R8 screws
plus rivets for above platenuts.
The detailed parts list can be found here.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-02-2017, 06:36 PM
j-red j-red is offline
Pm me if you want those brackets cheaper. I bought them but couldn?t use them due to using an old style narrower wheel pant.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
