  #11
Old 04-26-2018, 03:48 PM
YellowJacket RV9 YellowJacket RV9 is online now
That's odd. Mine hasn't shrunk in the 2 years and 220ish hours it has been flying, and it is still just as flexible. But I have heard other people complain of shrinking, also. Wonder if K&N changed materials at some point?
On another note, I did find today during my CI that the filter was beginning to wear a groove through the FAB floor. Filled it in and glassed over it...
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 04-26-2018, 03:50 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Originally Posted by RV7 To Go View Post
How are you guys getting hundreds or hours out go one of these air filters? I have 100 hrs on my stock O360 with stock Vans FAB using the K&N E3450 air filter. It came with the firewall forward kit and was oily and in a plastic bag when first installed last summer (yes I removed the bag). Checking it after 100 hrs and it has shrunk about 3/4" in diameter and is not flexible any more. Not flying in rain although light precipitation a couple times. What gives?
Al
Yep - common problem.
PM me your email address and I?ll provide photos on how I fixed this.
Carl
Old 04-26-2018, 04:01 PM
RV7 To Go RV7 To Go is offline
Thanks Carl. PM sent.
Al
Old 04-26-2018, 05:18 PM
lr172 lr172 is offline
How are you guys getting hundreds or hours out of one of these air filters? I have 100 hrs on my stock O360 with stock Vans FAB using the K&N E3450 air filter. It came with the firewall forward kit and was oily and in a plastic bag when first installed last summer (yes I removed the bag). Checking it after 100 hrs and it has shrunk about 3/4" in diameter and is not flexible any more. Not flying in rain although light precipitation a couple times. What gives?
Al
Variable rubber quality in china with limited oversight. A common plague of modern auto parts.
Old 05-25-2020, 09:51 AM
cjohngraham cjohngraham is offline
Default shrinking filter
Likewise, at the first annual (75 hours) on my RV-7A with O-360, the K&N had shrunk in height about 1/8". Diameter was still OK. To close the gap, I put a bead of red RTV on top edge of the filter. But Vic Syracuse (see his EAA webinars on RV maintenance) says that's a no-no because RTV can come apart and get sucked into the carb. He suggests fabricating a spacer from aluminum sheet and putting a layer of Proseal on it. Anyone had experience with this?
