Old 10-30-2017, 02:02 PM
Robin8er Robin8er is offline
Default Inspection requirments for new aircraft
Do new experimental airplanes require all inspections required for normal aircraft prior to receiving their air worthiness certificate?
In other words, do I need a transponder check and elt inspection prior to receiving my airworthiness inspection?
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 10-30-2017, 02:20 PM
Mel's Avatar
Mel Mel is offline
Default Negative...
You will need to conduct a condition inspection on the aircraft before scheduling the airworthiness inspection. The transponder check and ELT inspection is required before flight (transponder, depending on you specific location) but not for the airworthiness inspection. These are operational requirements, not airworthiness requirements.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-30-2017, 03:08 PM
Thanks Mel. Who does the condition inspection? i assume it cannot be me if do not hold a repairmans certificate.
RV-8 N695RA flying
Working on an RV-4
Old 10-30-2017, 03:13 PM
airguy's Avatar
airguy airguy is offline
Correct, for the airworthiness inspection you'll either need a DAR to come to you, or have the local FSDO send a guy to you. Both have pros and cons. I would recommend the DAR route, specifically Mel because he will do an actual INSPECTION of the airplane with hands and eyeballs rather than just a paper chase. If there is something wrong, he'll see it and bring it to your attention, which is what you really want to happen.
For the initial condition inspection, the builder does it, no repairmans certificate needed for that first one.
Old 10-30-2017, 03:23 PM
jwilbur jwilbur is offline
I think the local FSDO option is probably hit-or-miss regarding an actual inspection. I had a FSDO guy come and he spent about 4 hours poking with a flashlight into every part of the airplane. I had a page worth of things I needed to fix (all minor stuff, but still). It was invasive. But he did leave me with some confidence that the airplane was in good shape. I was actually relieved that it wasn't just a paperwork inspection.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 10-30-2017, 03:30 PM
Sam Buchanan's Avatar
been here awhile
Hey Mel...what's your fee for doing an inspection in Hawaii? Airfare and three nights in a nice hotel on the beach??
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-30-2017, 03:33 PM
Mel's Avatar
Mel Mel is offline
That would probably work. Of course that would have to be for 2!
Old 10-30-2017, 03:36 PM
Mel's Avatar
Mel Mel is offline
Like "AIRGUY" says, the builder does the initial inspection. You don't need the repairman certificate to do the initial inspection because it is not yet an "Airplane"!
Old 10-30-2017, 04:31 PM
Both myself and my DAR agreed with Mel: transponder check before flight (I'm in mode C required airspace) but after inspection was okay. But the DAR said he would check with the FSDO "just to be sure", and those guys said I needed the transponder checked first! Rather than argue with them, I just had it done. As others have noted, the builder must sign off the condition inspection prior to the AW inspection, including an ELT check.
Old 10-31-2017, 07:53 AM
airguy's Avatar
And if you're building and flying from a private strip that is not at an actual airport, like me, getting someone to come to you with a test rig can be an expensive and frustrating exercise. For me it was worth it, I'm 30 miles from the nearest airport and transporting the airplane was simply not worth the hassle.
