Fuel Tank Leak
I experienced similar leak on the RV-9A (8 years old at the time) fuel tank at the nose bracket. I removed the tank, drained fuel, pressurized the tank with 1 pound of pressure, and sprayed with soapy solution. When I was certain where the leak was, I removed as much old Pro Seal as possible, scuffed the aluminum parts and cleaned them with acetone.
Then mixed acetone with new Pro Seal to thin it out. Hook vacuum pump up to tank and suctioned it slightly. Coated the leaking area with "thinned" Pro Seal and let it set.
A few days later, I reinstalled the tank, filled with AVGAS and have been flying for five more years with no problem. YMMV
Don Johnson
Based at VA99 - Ophelia, VA
N754RK - RV-9A flying
N546DR - RV-7A flying
2020 VAF Dues paid
