Old 10-27-2017, 11:35 AM
SeanB's Avatar
SeanB SeanB is offline
Default Sealing QB Firewall
If I recall correctly, there is direction to seal the firewall and fuselage intersection using FlameMaster or a like product during construction. Because I have a QB fuselage, I'm imagining I will just lay a bead of product on the inside perimeter of this joint. Does this sound correct?
Thanks!
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 10-27-2017, 02:12 PM
gasman gasman is offline
That is the best way to do it as long as you do it early.
On the six we also run a bead along the belly skin at the wing root.
Sikaflex makes a nice caulking for this application.... look for it at ACE hardware. Remember, you are just sealing against CO & H2O. May as well make it as easy as you can to apply.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 10-27-2017, 04:25 PM
DanH's Avatar
DanH DanH is offline
3M FireBarrier 2000
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-27-2017, 04:27 PM
SeanB's Avatar
Thanks for the help, gentlemen. I will apply a bead along the interior intersection using 3M FireBarrier 2000.
SEAN BLAIR V7
2020 VAF SUPPORTER
