Old 10-26-2017, 05:57 AM
dwranda dwranda is offline
Default Sources for wiring and connectors?
Hello all!! Starting to get going on some wiring and wondering where everyone bought wire and connectors(dsub, etc) from. Did most just go Stein or is there some others I should consider?
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 10-26-2017, 06:15 AM
Bruce's Avatar
Bruce Bruce is offline
B & C aircraft and Stein are great.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 10-26-2017, 10:34 AM
sblack sblack is offline
yes, plus one. I got all my tools from B&C. Spruce has most of this stuff, but they resell B&C stuff as well.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 10-26-2017, 02:30 PM
Draker's Avatar
Draker Draker is offline
Not to hijack this thread, but question is related. I'd like to go, as much as possible, with MIL-SPEC round (Amphenol) connectors once I start wiring things up. But, they are so expensive, even used. Has anyone found an affordable source for these? I know, you get what you pay for but wow. I used to work in an avionics engineering company where we used these connectors exclusively and I have grown to trust them, but I never had to fork over my own money for them
Old 10-26-2017, 02:59 PM
Raymo's Avatar
Raymo Raymo is offline
Yes, the Mil-Spec are expensive, but they also use the same style pins (gold plating) as the D-Sub, which are relatively inexpensive and widely used. The tools to install/remove the pins are also less expensive.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 10-26-2017, 03:17 PM
bcondrey bcondrey is offline
You can also use AMP CPC (circular plastic) connectors. Series 2 uses the same pins as dsub connectors and are available in multiple sizes with several options for backshell, mounting, etc. Here?s one source: https://www.digikey.com/products/en/...tors/436?k=Cpc
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
Old 10-26-2017, 03:25 PM
bret's Avatar
bret bret is offline
I went with CAT Deutsch DTM gold plated pins and connectors for the important engine and electrical items. spendy crimper but it came out great.
Old 10-26-2017, 03:52 PM
Toobuilder's Avatar
Digikey has a good selection of DBx connectors that use MIL Spec crimp contacts.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-26-2017, 05:01 PM
BillL BillL is offline
Being close to the end of building I have drawn some conclusions. I did not use connectors for panel and wings. It would have helped greatly with some advance planning. If you are sourcing a panel, then the connectors make good sense, you can install the long runs and just connect them when installing the panel. Wings: if you are wiring and building in the a hangar, maybe ok to skip wing root connectors, but if you are building at home (like me) they would be a great help for final assembly. Planning takes time, connectors cost money, but both will save huge time on final assembly and allow that for systems adjustments and checkout.
The Deutsch DT connectors are really tough. Buy the kit from a Cat dealer with the crimper and the box of connectors is nearly free compared to the crimper alone. The DT's are good for high vibration and sealed against corrosion.
There will be a lot of different connectors (and terminals), lighting, engine block heater, and other items that come with connectors (alternator). DigiKey is good, Mouser too.
Bill
RV-7
Lord Kelvin:
Old 10-26-2017, 05:30 PM
wjb's Avatar
wjb wjb is offline
I'm using TE Connectivity AMP CPC (circular plastic connector) Series II for signals. These use the same 20 AWG pins as the MIL SPEC connectors (and the same as the low density D-subs). I got mine at Mouser, but most suppliers have them.
For power connections, I'm using Deutsch DT and DTM connectors. These are great since they are environmentally sealed, and I plan to use these, too, in the wing roots and other areas more exposed to the environment. I got mine at https://www.deutschconnector.com
The quality to price ratio is very high for both...
Bill Bencze
