10-27-2017, 10:12 AM
When I took the ROTAX course the instructor had a home made setup using the manifold pressure gage from a twin engine aircraft. It worked great, but the Carbmate seems to have a better resolution than what you can see on the analog gage. On the other hand maybe ?close enough? is good enough.
10-27-2017, 02:26 PM
Richard...what airfield are you based @ in Phoenix?
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
10-30-2017, 01:00 PM
Glendale. Desert Hangar Owners Hangar #24.
10-30-2017, 02:28 PM
I am seeing a 0 to 56 degree delta (right side higher).
I was told (at my 200 hour / annual) this was good and no balancing was necessary by the mechanic doing the work. Is this consistent with what you are finding?
B2RV12
10-30-2017, 02:46 PM
Personally I don't consider EGT as a reliable indication of carb. synch/balance. If it was reliable I think Rotax would have put it in the maint. documentation.
Scott McDaniels
Hubbard, Oregon
10-30-2017, 04:27 PM
I balanced my carbs with two vacuum gages. When I was satisfied that they were closely synched I then transferred the vacuum gages L>R to make sure they was no gage bias. I then looked at EGT's for idle and off-idle and they are very closely matched. I frequently monitor the EGT's and will re-balance if differential ever changes...
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
10-30-2017, 09:19 PM
Above about 4000 RPM the intake manifolds will have the same pressure unless your throttle cables are completely out of whack, so I would not expect cruise RPM to be a good indicator of synchronization. The ROTAX instructor told us that is why you do the ignition check at 4000 RPM: to eliminate carb synch as a factor in rough running during the check. It makes sense considering the throttling profile of a butterfly valve. After about the first 50 degrees of rotation they have little restriction to airflow.
06-07-2018, 06:39 PM
Hi, can changing spark plugs or prop dynamic balancing or adjusting/correcting prop blade pitch affect carb sync?
06-07-2018, 08:33 PM
I would hardly call myself the ROTAX expert, but I don?t see how prop pitch or spark plugs would affect carb balance.
06-07-2018, 09:12 PM
I?ve tried several dual gauge set-ups; but I like best the dual-needle gauge like Tony uses. Set your off-idle adjustment first @ 3800 rpm. Then adjust idle sync & idle rpm with your idle screws....she?ll purr like a kitten.
Ric Dickison
307 (CAB) Phantom
2018 Dues Paid
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
