Old 02-22-2007, 03:07 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Default Unheated Pitot Choices
I've decided to go with an unheated pitot (for now) but I have installed the SafeAir1 pitot mount to provide me long term flexibiliy.
The only unheated pitot tubes I have located, that will fit the SafeAir1 mount, are the Gretz G-500 and the Dynon AOA pitot. I am not a huge fan of the look of the Gretz and while Dynon is fine, I don't need the AOA (I know it doesn't have to be used). Are there any other unheated pitots out there that I have missed?
Thanks!
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 02-22-2007, 03:38 PM
frankh's Avatar
frankh frankh is offline
Default Yup
The ugly piece of bent brake line...Almost zero cost and sported by all of Van's demonstrators.
Incidently, I cut the hole for the Gretz mount as i will be upgrading to the Dynon heated probe just cus.
After I did this I made a temporary flat plate that screws in place of the Gretz mount and the brake line version is bolted to a hole in the middle.
When I get my Dynon probe it swaps out with 4 screws.
Frank
Old 02-22-2007, 03:49 PM
briand's Avatar
briand briand is offline
http://www.evansaviationproducts.com...20Products.htm
Old 02-22-2007, 04:13 PM
RV7Factory's Avatar
Thanks guys.
Frank - Ironically, since I posted the orignal question, I have been thinking of doing pretty much exactly what you did. Modify the SafeAir1 mast to make it removeable (like the Gretz) and then fabricate a filler plate where I can mount the stock Van's pitot. Keeps it simple, flexible, and cheap. I am still thinking about this, but it is definately high on the list now. Thanks!
Brian - Thanks, I knew there was another one out there! At $230 it is kinda steep for what I want to do (cosidering I already have the SafeAir1 mast), but maybe he would sell me just the pitot tube. It's an option... Hmmm.
A somewhat related question...
Does anyone have the instructions and materials list for the Gretz mast they could scan and email or fax to me? I can figure out how to modify my SafeAir1 mast on my own, but the Gretz instructions may give me a leg up. PM me if you can. Thanks!
Brad Oliver
