Old 10-21-2017, 09:44 PM
jwilbur jwilbur is offline
Default how to test a slickStart
I strongly suspect my slickStart is not doing what it should. For the first many flights I had no trouble starting the airplane. One or two blades and it's running. Lately, not so much. No change to my starting procedure but it just doesn't want to go. When it does catch it's all fine. But man, the battery is getting a workout.
What is the easiest way to test the slickStart unit to see if it's doing its job correctly?
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 10-21-2017, 11:16 PM
Well, here?s one way.
Disconnect the starter cable. Cover the end with tape or shrink wrap.
Pull the plug on #1 that?s connected to the left mag (assuming that?s the one connected to the Slick start). Re-connect the high voltage lead to the plug. Lay the plug on the cylinder where it?s in contact with ground.
Ignition off, mixture idle cutoff. Be careful.
Turn the prop slowly, normal direction, until you?re on the number 1 compression stroke.
Have an assistant turn and hold the key on start. (If solo, jumper the start lead to 12 volts and leave the key on left).
Slowly move the prop toward TDC.
As you get there, you should see multiple sparks jump the plug gap, if the Slick start is working.
Old 10-22-2017, 06:54 AM
Jesse's Avatar
Jesse Jesse is offline
You could also check the inline fuse.
Jesse Saint
Old 10-22-2017, 06:58 AM
6 Gun 6 Gun is offline
Default Points
Check your points also
Bob
Old 10-22-2017, 01:38 PM
Janekom's Avatar
Janekom Janekom is offline
Another key symptom when it fails is if your motor tends to fire or start just as you release the start key. But the retard set of points not opening on the retard magneto will do the same.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
Old 10-22-2017, 01:59 PM
Only had a few minutes today so just checked the fuse. Fuse was fine. Was hoping for an easy fix.
Does the slickStart "buzz" when engaged?
Phase II - 11/2017
RV-10 Build Log
Old 10-22-2017, 02:13 PM
F1R F1R is offline
If you have a mag timing box, you can verify that the retard breaker points are opening and closing, and also check that they are opening at the right time. Check the mark plate on the mag for the Lag Angle. it should be after TDC in any case.
Old 10-22-2017, 06:54 PM
F1R F1R is offline
Default TT on Mag?
On the mag the SS is connected to, how many hours since NEW on the MAG
and how many hours since OH?
Old 10-22-2017, 06:57 PM
Still in phase 1. 26 hours total on everything since new.
Phase II - 11/2017
RV-10 Build Log
Old 10-23-2017, 06:12 AM
F1R F1R is offline
For what it is worth I recently had a new 6393 suffer infant mortality in less than 5 hours flight time. The starting points worked fine in this case but the normal points went from totally normal to totally non operable in the last 2 hours. It was under warrantee, so there was no need to open it up and have a look inside. Shaking the mag it sounded like a baby rattle. However using a mag timing box allowed backup proof with a video of the problem.
I am not saying this is your issue, but it could be. Just remove the p leads on both the retard points and the normal points. Hook up the left lead to the P lead. Ground to the mag case. The right lead the the retard points post. The normal points should open at your desired timing of 20 or 25 BTDC and the retard points should open after TDC. It sounds like they might not be opening at all.
If it checks out OK then perhaps it could be the SS or a fuel issue.
