Old 10-21-2017, 08:54 PM
Robin8er Robin8er is offline
Default Fuel pump clicking
I'm working on my electrical system and did the first test today. When I turned on the fuel pump it made a clicking noise. It sounded similar to the noise that a car with a dead battery makes when the starter clicks rapidly. It is the stock pump from vans for a carburetor.
Is this normal or do I have a bad fuel pump?
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 10-21-2017, 09:25 PM
rv7charlie rv7charlie is offline
The Facet boost pump is basically a solenoid driving a piston with a couple of check valves. It will click rapidly until it primes, and the clicking will slow as the downstream fuel line fills, the float bowl fills, and eventually the clicking will stop once pressure builds to the pump's design pressure.
edit: don't continue to run it dry; it needs fuel to cool the coil.
Old 10-22-2017, 01:24 AM
Thanks. The manual said to test it for a few seconds, but thats not the sound that I was expecting.
RV-8 N695RA flying
Working on an RV-4
Old 10-22-2017, 06:45 AM
Yep rapid clicking until it actually draws fuel then the clicking volume goes down.
How are things on Oahu??
Tom
Ridgeland, SC
